Rear Motor Mounts
Old Jul 30, 2010 | 02:11 PM
piledrive's Avatar
piledrive
Stage II
Default Rear Motor Mounts
Brand new to this Form. Need a little help. My Son-in-Law has a 1995 Wide Glide that has gone through three rear mounts in the last couple of years. (guessing under 15000 mi since the first replacement.) Has any one else had this problem? He has done the work himself. Is there something that he is not doing. Is this an engine alignment problem? Any input gladly accepted
Old Jul 30, 2010 | 02:57 PM
stng_96's Avatar
stng_96
How do you know that the mounts are failing? Does it just feel like its vibrating alot?
Old Jul 30, 2010 | 06:29 PM
Just Enough's Avatar
Just Enough
I would think that a spruthe or true track would limit the motion of the mount and possibly make it last longer. I have not tried either but looking at how they are mounted they eliminate the lateral motion of the mount.
Old Jul 30, 2010 | 06:44 PM
piledrive's Avatar
piledrive
Stage II
I helped him do the R&R and in each case the rubber was torn from the metal bracket on both sides. No question about what failed.
Just talked to him on the Phone and He reminded me that the front one failed first, then after that we replaced the rear twice.
Engine alignment???????
Old Jul 31, 2010 | 08:27 AM
DXrider's Avatar
DXrider
If the motor isn't alinged it would shake the fillings out of your teeth before it tore a mount. I don't think thats the problem. Does he ride it hard, wheelies and burnouts? A truetrack will stop it. Is the frame straight?
Old Jul 31, 2010 | 04:15 PM
fxdx-fly-by's Avatar
fxdx-fly-by
are you sure the front one is the right one?... seems like if it were off then it would throw the back off...just a thought..
paulvs
Nov 8, 2017 06:54 PM
Son of PMS
EVO
18
Jul 22, 2014 08:39 PM
JohnnyRebKY
Jun 10, 2014 11:47 AM
Brettfullthrottle
EVO
23
Jul 19, 2009 07:33 PM
magna3500hd
Jan 7, 2007 08:21 AM
