Gettin' pissed
Old Aug 8, 2010 | 10:38 AM
essentialcycle's Avatar
essentialcycle
So during my testing, I thought I had it figured out. I did not have voltage on one wire while testing the diode. I then started wiggling wires and had spiking voltage. I was movin the wires at the base of the regulator. I took the regulator off and used my meter on ohms. I hooked one end on the wire that goes to the relay by the seat and one of the plug ends on the regulator. Follow me? I then wiggled and pulled and got big time resistance reading changes. I pushed and tugged on the wires and onlt one was faulty. It's right where the wires go into the regulator. Thinking this is the problem.
Old Aug 8, 2010 | 11:17 AM
kk6pg's Avatar
kk6pg
You deserve a pat on the back. Now fix it up and ride
Old Aug 8, 2010 | 04:51 PM
08fxdf43202's Avatar
08fxdf43202
That's what was wrong with mine! Both metal tabs in the connector were broken on the battery side of the regulator. I think I'll check the stator side for the same condition.
Old Aug 8, 2010 | 06:48 PM
Jackie Paper's Avatar
Jackie Paper
Default Picture
If you check the stator side for the same condition how bout attaching a couple of pictures of the plug on the engine and it unpluged. Thanks
Old Aug 8, 2010 | 08:26 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Your 95 is a two phase charging system, some 04's and newer went to three phase(hence three wires) I replaced my reg/rectifier with one from Cycle -Electric, I've gotten good service from it.
alee18
Aug 8, 2018 03:21 PM
RoadKingAnni562
Electrical/Lighting/Alarm
Apr 25, 2018 02:31 PM
jefla
Jun 29, 2014 01:30 PM
intense883
Oct 4, 2013 10:02 AM
waycool'76
Feb 8, 2010 04:05 PM
