VIBRATION issues??
Old Sep 3, 2006 | 11:35 AM
rickshog's Avatar
rickshog
Default VIBRATION issues??
OK... I have a 06' superglide with V&H pipes a/c and PCIII. My bike runs great. My dad has 06' dyna 35th with screamin pipes a/c and download. I rode his to the dealer for the 1k service and the buzzing vibration from the seat was so annoying I dont think I could have ridden the bike 30 miles straight. Vibration problem seems to come in at the same RPM range in every gear (like 2100-2600 rpm) Dealer said he did feel a vibration and called harley who sent him a motor mount. He put it in and said it was fixed. I came by and rode it and there was clearly no differance. Told him and now he says there is an exceptable amount of vibration. Clearly he thought there was a problem and he says there may not be. The regional guy is coming on tues. to ride the bike. Was wondering if anyone had any ideas for me. Like I said I have pretty much the same bike and the differance is BIG. Sorry about the long post but thanks!!!
Rick
Old Sep 3, 2006 | 11:40 AM
voyager1's Avatar
voyager1
Default RE: VIBRATION issues??
i have read many reports on loose motor mounts,might wanna check those .. sure not norm .
Old Sep 3, 2006 | 11:53 AM
rickshog's Avatar
rickshog
sorry.... forgot that... They said they loosened all mounting bolts and tightened them from back to front as per harley.
Thanks
Rick
Old Sep 3, 2006 | 01:28 PM
stubby's Avatar
stubby
Check the belt. Both actually. My vibration was caused by the drive belt being within rec., but causing the vibration. The mech. realigned the rear wheel and gave me a little more play.
Old Sep 3, 2006 | 03:49 PM
rickshog's Avatar
rickshog
well.... maybe thats it... I just want the guy whose gunna be test riding it to tell me that t5here is nothing wrong with the bike.
Thanks again
Rick
Old Sep 3, 2006 | 05:49 PM
dynamolowrider's Avatar
dynamolowrider
you might check compresion and see if thers a difrance between cylinders.one cylinder might not of seated properly.had that hapen on a old ironhead sportster.
Old Sep 3, 2006 | 09:43 PM
WS6 Formula's Avatar
WS6 Formula
Vibration Fix, read post#4
Old Sep 4, 2006 | 02:52 AM
DougsDyna's Avatar
DougsDyna
Did the dealer loosen the mounts, and then run the engine for several seconds on the stand?
This is Harley's procedure to align the engine on the frame.
Just my .02
DD
Old Sep 5, 2006 | 03:35 AM
docsg's Avatar
docsg
ORIGINAL: rickshog
Rick
I had a similar problem with my 05' FXDL. At 2500 miles I asked the service manager to ride it and he agreed that the vibration (buzz) in the handlebars and pegs were more than would be expected. They changed the motor mounts and did a series of other "fixes" suggested by the Motor Company. Nothing really changed. The regional rep rode it and agreed that the vibration was a little more than normal. At first they tried to tell me that it was normal and would subside somewhat after I put more miles on it. I told them that was "b*** s***" as this was my second twin cam FXDL (first was an 01') and it was smooth. Bottom line-the regional rep okayed an engine swap as suggested by the service manager (complete new engine) and since then it runs great (and only a minimum of vibration). Since all this occured in July of 05', they also offered me a great deal on an 06' if I was not satisfied. I'm now glad I kept the 05' as it is a great machine and I will probably wait untlil the 08's to trade to make sure the new engine/tranny combo has all the kinks worked out (although I'm now convinced that all model years have one kink or another). For example, I just had the horn changed out because the dealer said the factory installed a run of defective horns in late 05' and mine was one of the defective ones. BTW, my dealer is HD of Montgomery (AL) and they have given me nothing but top notch service (and they didn't pay me to say that!!)
Old Sep 5, 2006 | 03:55 PM
Stanger's Avatar
Stanger
Finally, a possible answer to my vibration problems!! Thanks everyone!!!
jcannady
Jun 8, 2010 10:16 PM
ghostrider69
May 21, 2010 09:58 PM
newtsqueensy
Aug 30, 2007 08:23 PM
newtsqueensy
Aug 26, 2007 10:49 AM
sj9125
May 29, 2006 02:31 PM
