FOB delete?
Old Aug 15, 2010 | 12:58 PM
HDTech74's Avatar
HDTech74
Originally Posted by 08fxdf43202
I added the security feature to my 08 by replacing the Turn Signal Module (TSM) with a Turn Signal Security Module (TSSM).
Unpluged the one & pluged in the other. All you need is a TSM.
I'll trade you (or jaysonL) even... my TSM for your TSSM & fob. I'll send you mine 1st, you unplug your's & put it (with the fob) in the USPS Priority box mine comes in (I'll include a shipping lable). Install mine & if everything works... ship me your TSSM & fob.
If mine does not work for you... ship it back to me.
Easy... peasy.
You can't just unplug the TSSM and plug the TSM in and be done with it.
You need Harleys digital technician to MARRY the TSSM/TSM to the ECM.
Go ahead and try without marrying them together, the bike will start for about 2 seconds and then shut off.
Old Aug 15, 2010 | 01:49 PM
fskitch's Avatar
fskitch
bigmikaele, the only problem is after you disarm the security system via the owners manual instructions is it will rearm itself after turning off the key the first time.
Old Aug 15, 2010 | 02:33 PM
HDTech74's Avatar
HDTech74
true, you'd have to disable it everytime after.
I'm also pretty sure you could have the dealer put it in service mode also.
But if you're unsure about it, I would just ditch it.
My bike is protceted by mossberg and S&W and a ka-bar. If you get by those, you can have it.
Old Aug 15, 2010 | 03:02 PM
LWOS's Avatar
LWOS
Is it just me, or wouldn't be simpler to remind yourself to just replace the key fob battery every 3 years? I have my computer's calendar programmed to pop up and remind me to replace furnace filters, smoke alarm detector batteries and my FOB batteries. Why do you guys like to make things a major projects.
I have a 2007 Low Rider and Old Man has a 2006 FLSTC. We've Never had an ounce of problems with the FOB's and replaced the batteries last winter.
I did take the suggestion from one rider. His FOB broke apart from the constant battering from the wind against his Dyna's frame. He put a piece of velcro on the FOB and FRAME....then attached the FOB after he put his key in. No more banging around when he rode, saving the FOB from further trauma and as an extra bonus, when you turn the key off to get gas and the key pops out.....it wont drop to the ground!!!
Old Aug 15, 2010 | 03:58 PM
nevil's Avatar
nevil
Make it easy on yourself. There are lots of places on the bike you can secure an extra fob battery so you can have a back up handy. You can even keep one in you wallet.
Old Aug 15, 2010 | 04:51 PM
BLK08ROCKERC's Avatar
BLK08ROCKERC
I had the dealer disable my security before mine even left the dealership. Way I see it is that if someone wants my bike, that security isn't going to stop them.
Old Aug 15, 2010 | 05:23 PM
wlbowers's Avatar
wlbowers
Originally Posted by kenfm2000
I Believe you are correct. All a thief has to do is replace your TSSM with a TSM and security disabled. That is security at it's best.
Not that simple
Old Aug 15, 2010 | 07:10 PM
markrumsfield's Avatar
markrumsfield
If your fob takes a dump you can disarm the security system using using the turn sig buttons and your pin and the bike will start. I carry my fob in my pocket so it doesnt bang around the frame when Im riding plus if I forget to take the key out when I stop, and Ive done that a few times, the bike wont start if some one tries to steel it...
GreatGrandBrother
2014-2024 Touring Models
Jun 1, 2017 08:56 AM
June Bug
Jun 4, 2014 09:40 PM
JSprGldeMathis
Jan 18, 2011 11:58 AM
beary
Mar 6, 2009 04:12 PM
Kong
Jan 14, 2007 08:29 AM
