need shock advice
Old Aug 16, 2010 | 08:47 PM
bugzapper's Avatar
bugzapper
Default need shock advice
Purchased a used (2004) Wide Glide that did not have an owners manual. I have not purchased a service manual yet. The problem is when riding with passenger it seems to bottom out on bumps pretty often. Are the stock shocks on a 2004 Wide Glide adjustable ? When I look at them you can't see anything to adjust.
Old Aug 18, 2010 | 03:57 AM
bigVtwin88's Avatar
bigVtwin88
They are adjustable. You just need a spanner wrench to turn 'em. You sure they're stock length? (12.5")
Old Aug 18, 2010 | 08:02 AM
FastHarley's Avatar
FastHarley
Former Sponsor
Every shock has a "Lifespand" and it either must be re-built or replaced. depending on your mileage this may or may not be your case. Check it out yourself to see if that is the case which I am not saying.
Old Aug 18, 2010 | 09:50 AM
NOZEM's Avatar
NOZEM
Congrats on the bike dude! Your shocks are adjustable, there should be numbers on the "rod" if you peek between the spring. You need to turn clockwise with a spanner wrench. Go to next number and test, experiment at different speeds... set both side the same
Canadianbear
Sep 4, 2014 09:05 AM
oakley24_48
May 30, 2012 04:27 PM
lhgdale
Oct 28, 2009 03:47 PM
MrZorba
Jan 15, 2007 12:51 PM
Mrkicks
Oct 20, 2005 10:23 PM
