True Track
Old Aug 23, 2010 | 06:54 PM
SC-Longhair's Avatar
SC-Longhair
Default True Track
This is what happens when you don't check your bolts every once in a while:
Actively working with True Track to get that front bracket in proper running order.
Old Aug 23, 2010 | 07:01 PM
mentor70's Avatar
mentor70
yikes, i need to run outside......ill be back
Old Aug 23, 2010 | 07:12 PM
SC-Longhair
Oh and yes I've searched high and low locally to rebuild the stabilizer but no one in a 75mi radius stocks heim joints.
Old Aug 23, 2010 | 08:18 PM
AFHuey's Avatar
AFHuey
wooops
Old Aug 23, 2010 | 08:36 PM
EricInNCa's Avatar
EricInNCa
Note to self - Add the True-Track bolts to the "critical fasteners" lists...
ps: I don't have a True-Track yet but will definitely be adding one sometime.
Vic, so it just loosened up and fell off?
Old Aug 23, 2010 | 09:22 PM
NoLongerAmember's Avatar
NoLongerAmember
No Grainger near you?
http://www.grainger.com/Grainger/wwg...N=0&sst=subset
Old Aug 23, 2010 | 11:32 PM
Wireguided's Avatar
Wireguided
Bum Deal Vic......
Old Aug 24, 2010 | 12:04 AM
lo-rider's Avatar
lo-rider
Default Loctite
This is what happens when you don't check your bolts every once in a while....
...Or forget to use Loctite.
Yeah, following a 7-day trip I washed the bike, only to discover that the fasteners on the front exhaust pipe were WAY loose, and had created a small burn-mark. Also found the switch housing loose on the handlebars.
Note: check w/ McMaster-Carr.
Old Aug 24, 2010 | 12:11 AM
JekyllnHyde's Avatar
JekyllnHyde
DAAAAMN. I'm going to go check mine now.
Old Aug 24, 2010 | 06:07 AM
Krazy8s's Avatar
Krazy8s
ooops.
Did you notice any difference in the ride after it fell off, or just noticed when you got home?
