steetbob 200 tyre
Old Sep 7, 2006 | 12:14 PM
spongebob's Avatar
spongebob
Default steetbob 200 tyre
hi
was looking at the 2007 softail i was interested in the 200 tyre looks really good then i looked at the belt drive they,re using a thinner belt and it got me a thinking could you use the thinner belt on the streetbob and just change the rear sprocket maybe have to put a spacer on for the wheel sprocket?and fit a 200 tyre there,s enough room under the fender maybe move the the brake line and with the thinner belt it would fit.
Old Sep 7, 2006 | 12:29 PM
grunt's Avatar
grunt
Default RE: steetbob 200 tyre
I think there is swingarm issues to deal with. I think someone posted the mods needed somewhere in this forum. Try a search.
Old Sep 7, 2006 | 01:07 PM
spongebob's Avatar
spongebob
I,ve looked at the swingarm there,s plenty of room width wise it,s weather the tyre circumfrence is bigger, its one measurment i never checked
Old Sep 7, 2006 | 06:02 PM
Zyklon's Avatar
Zyklon
Grunt is right, even the 180 tire does not leave much room to work with. If the dealer would have installed it I would have had a 200mm tire installed on my Wide Glide instead of the 180mm. I am not saying that you can not force a 200mm in there but I think that it would take one of the after market swing arms to make it work right, with adequate clearance and any margin of safety. IMHO
Zyklon
Old Sep 7, 2006 | 08:39 PM
jackyl's Avatar
jackyl
just do the 180 tire,looks almost the same.and it wont cost you that much for the mod.instead of paying for a custom wheel in the back FOR A 200.if your going to do that throw a 240 or 330 on it,if your going to go big GO BIG.if not just do the 180 IMO
Old Sep 8, 2006 | 07:16 AM
spongebob's Avatar
spongebob
you wouldn,t have to replace the wheel just go for the thinner belt drive and tyre cheaper than replacing the swing arm.
Old Sep 8, 2006 | 08:19 AM
dav.elis's Avatar
dav.elis
See this at Dyna 2006 200 tire: http://www.hdwheels.com/New%20Product.htm
Old Sep 8, 2006 | 10:26 AM
spongebob's Avatar
spongebob
good link thanks
Old Sep 8, 2006 | 12:19 PM
hd lady's Avatar
hd lady
Our Bob came with the dealer installed 200mm rear tire. There isn't that much of a difference looks wise but ride wise it's a whole different ride.
Old Sep 8, 2006 | 02:31 PM
glebo's Avatar
glebo
watch out for the turn signal wires also in the inside of the rear fender. You may have to re-route them so the tire does not rub them when the shocks compress over bumps/passenger. It looks to me it may be a little close on the wires.
