tts mastertune map
Old Aug 29, 2010 | 09:30 PM
lhcstreetbob's Avatar
lhcstreetbob
Default tts mastertune map
I just replaced my pcv for a mastertune tuner i did the install today today ......it wasnt to bad the only thing i wasnt to sure about is the base map ....there isnt one in the list that is really that close to what i have? does anybody have a tts map that would work until i do the v tune? thanks
Old Aug 30, 2010 | 03:01 AM
==ShaDoW=='s Avatar
==ShaDoW==
let me guess,,,,,,,,,, nope not a physic, how about some information, pipes? AC?
Cam? head work?
Old Aug 30, 2010 | 07:03 AM
SC-Longhair's Avatar
SC-Longhair
I've seen the map list and there are plenty of 103 maps...looks for the ones that mention 1690cc. You may not find your exact cam setup but you'll be close.
Old Aug 30, 2010 | 12:25 PM
lhcstreetbob
thanks vic ill look through the maps again
Old Aug 30, 2010 | 12:32 PM
SC-Longhair
I found the list to be a bit confusing so I could see how you might have missed them. See if you can find one where the SE cams are close to the 54's. That's what I would do. That, or try contacting TTS.
Just did some comparing of cams on bigboyz. SE255 has similar lift to 54's. Not exact but close.
Old Aug 30, 2010 | 12:35 PM
lhcstreetbob
right on man thanks i did some more playing with it, and you can change the displacement ...its a pretty cool program just going to take me some time to dial it ....
Old Aug 30, 2010 | 12:41 PM
SC-Longhair
Good luck. I hope to be doing the same thing soon. Not happy with my pcIII and never really have been.
Old Aug 31, 2010 | 06:04 PM
lhcstreetbob
i found a map its for a 103 with 255 cams but not a 2 into 1 but it seems to run great ..this tuner is pretty cool ..
Old Aug 31, 2010 | 06:11 PM
SC-Longhair
Excellent man. I'm sure a couple of Vtune runs and your bike will be just purring along.
Old Aug 31, 2010 | 06:20 PM
Grind's Avatar
Grind
Hmmm... the more I read about the TTS, the more I think it'll be on my short list.
waffler
Jul 5, 2020 06:25 AM
steelpony16
Oct 17, 2017 08:30 AM
supra0001
Apr 16, 2013 05:39 PM
The Roadrunner
Mar 27, 2012 08:00 PM
rm4040
Jul 21, 2011 12:42 PM
