Tmax help (106 build)
Old Aug 31, 2010 | 05:05 PM
masterblaster's Avatar
masterblaster
Default Tmax help (106 build)
Okay I am getting my build complete finally.
Big Boyz street ported heads/ larger springs to handle up to 650 lift cam (In case I change my mind later)
S&S 570 ES cams
S&S 106 BB kit 10.2 - 1 compression
Bub 7 2-1 exhaust
What map do I use in teh TMAT?
Old Aug 31, 2010 | 05:57 PM
JRK5892's Avatar
JRK5892
dyno that sucker bud, with all that work into it. your going to get the most out of it with a custom map from a tuner, i personlly would not even know where to begin
Old Aug 31, 2010 | 06:05 PM
masterblaster
I will eventually but the only Dyno tuner I trust is in Dallas 1200 miles away so I wont be able to ride there til Nov Dec. Ed at Dynodifference.
Old Aug 31, 2010 | 09:21 PM
nevil's Avatar
nevil
If you can't find anything close with all their base maps call tech support at Zippers. 410-579-2828x120. They should be able to recommend one and have about 10 new maps to download.
Old Sep 6, 2010 | 07:36 PM
Maddgrinch's Avatar
Maddgrinch
Stage I
Default S&S 106 Tmax
Build Specs are 2008 ultra, S&S 106 kit with big boyz porting,crank trued welded plugged and lightened,D&D quiet baffle,SE 204 cams.
Ordered Tmax from moto with a custom map, ran like crap ,timing curve not even close.I tried map 29 alot better but still not good.What i did was copy timing from map 399 old non tbw maps into tbw map 29, bingo runs pretty good.Map 399 is for andrews 37 cam very close to 204 cam specs.After trying a bunch of different maps i am of the opinion that the first thing to match up is cam timing with the Tmax, then the rest or it will never run right.
I am going to change the cam in the future,the 204 with early intake close is not the best for me because of detonation and having to retard the timing down low to compensate.The Tmax is easy to tune and use ,but you must have the timing right.
Old Sep 6, 2010 | 07:44 PM
domenicp7's Avatar
domenicp7
Good choice on chosing Ed one of the best.
Old Sep 6, 2010 | 07:59 PM
AFHuey's Avatar
AFHuey
I was setting mine up this weekend before it took a dump on me. According to ZIPPERS, the 103 map with your setup will be close enough to get you in the ball field. Are you using the autotune module? If so, just crank in the 103 map and you'll be in the ball park. If not, call them but I think it should get you to the dyno.
Old Sep 24, 2010 | 09:06 AM
masterblaster
The heads are coming in today from Bigboyz, waiting on the cam tool from Gary Beaty, ordered this morning. Hoping to have motor back together next weekend.
Still wondering what map to use for this build, appreciate any advice.
Old Sep 24, 2010 | 09:12 AM
nevil's Avatar
nevil
You might want to call Tech support at Zippers (410-579-2828x120), they have some new maps available now.
Old Sep 24, 2010 | 09:22 AM
masterblaster
Thanks nevil, just talked with them they recommended the 553 then 398, their maps are for dished pistons but he said this will get the cam close so timing sould nt be an issue. Now to assemble it without screwing something up.
