Overheated
Old Sep 1, 2010 | 11:40 PM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Originally Posted by wlbowers
Someone want to explain to me how his bike went into harleys overheat mode when:
He is running a Thundermax.
+1 The Tmax replaces the ECM if I am not mistaken. But in any case that is why I run synthetic oil. That one shot over 300F can really do some damage.
Old Sep 2, 2010 | 12:00 AM
SURFOR Chop's Avatar
SURFOR Chop
Couple of observations:
- the TMAX reads head temps ... head temp will run a little hotter than the oil temp ... which is why oil cools the motor ....
- check your IAC Curves (Idle Speed vs. Engine Temp) ... my idle starts to go up as the head temp goes above ~310 ... (not to 2,000 RPM, but a few hundred RPM) ...
- also, the ECM Module Configuration (Basic Settings) allows you to set where you want the high temp warning to start ... you might check to see what yours is set at ... might be a rather low setting which was giving you a 'false' alarm that the motor was in a worse state than it really was ... (or not) ....
Hope the heat didn't do any damage ... you did the right thing shutting down and cooling off ... wouldn't think 90 degrees ambient temperature would be that 'arduous' of running conditions ... for many riders (particularly, AZ, TX, FL, SoCAL, etc) that's probably considered mild ....
R/
'Chop
fourburgs
Milwaukee Eight (M8)
Jun 29, 2017 05:04 PM
berniemc
Jun 16, 2015 10:06 PM
EagleRay
Dec 1, 2013 05:45 PM
magnum629c
Apr 14, 2013 11:05 AM
mmeddle1
Apr 2, 2012 04:05 PM
