Checking engine oil Level...
Old Sep 5, 2010 | 08:27 PM
racer11's Avatar
racer11
Default Checking engine oil Level...
2000 TC-88 engine.
I've never been sure about this,,,,when checking the oil level, do I push the rubber cap all the way in and remove it and note the oil on the dip stick.
Or
Push the cap in to the first stop (about 1/2 way) and check it from there.
Right now when I put in 3 quarts and check it from pushing the cap all the way down it shows overfilled,,,,,half way in shows just right.
I guess I'am a bit slow,,it has taken me 10 years to decide to ask this question.......:shrugs:
Thanks....
Old Sep 5, 2010 | 10:40 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
The oil quantity during an oil change is 2 1/2 qts., so you overfilled it. Get yourself a food baster, clean one, and suck out a half qt. the oil is checked with the dipstick fully seated with the bike on the jiffy stand. When the engine is at operating temp the oil should be no higher than the full mark. Pre ride check just check to see if you have oil between add and full. I check mine after I get home, and before the next ride I look for oil under the bike. If it's not on the floor than it's still in the bike.
Old Sep 5, 2010 | 11:04 PM
racer11's Avatar
racer11
OK,,,,thanks, Tomorrow I will suck that extra oil out of there before I ride.
Lee
pomeara
Milwaukee Eight (M8)
15
Jun 8, 2017 10:23 AM
Pale Horse Rider
Jan 15, 2015 12:05 PM
scasey
Feb 14, 2010 09:42 PM
reecard
Apr 24, 2008 05:57 PM
Kski
Oil Archive (no new posts)
Mar 19, 2008 12:04 PM
