Rear brake problems for 07 dyna bobber
Old Sep 9, 2010 | 01:50 PM
drillsergeantus's Avatar
drillsergeantus
6th Gear
Default Rear brake problems for 07 dyna bobber
Hi all,
Havent been on in a while but read most of the posts. Ive finally got tired of taking my bike to the shop for the yearly maintenance and started doing it myself. Just ordered a bike jack and in about a week I will be pulling the back wheel off for the first time by myself. Sure for most of you its simple but for me its a major task. But anyway...Im having trouble removing my rear brake pads on my 07 street bob. I cant pry the pads back as it states in the manual. Just want to know how am I screwing up and should I just wait for my jack and do it that way.
Thanks
Old Sep 9, 2010 | 01:58 PM
JRK5892's Avatar
JRK5892
have you removed the pins from the caliper? there should be 2 12 point bolts on it, i can not recall what mm off hand they are, but you first remove that and then you cna get them back... that is awesome you are doin gthis on your own man, we can help you out on here!
Old Sep 10, 2010 | 10:23 AM
drillsergeantus
6th Gear
yep. I got as far as loosening the bolts but the problem that Im having is removal of the brake pads. I loosened the master cylinder and I cant find anything to pry the pads back for removal without damaging my rotor. I read somewhere about using a wood wedge. I talked to a few of my bros at the HOG meeting and one of them suggested using modified flat-tip screwdrivers but still working on it. I get my jack on the 14th of this month.
Old Sep 10, 2010 | 10:41 AM
cmonster's Avatar
cmonster
looking at the caliper from the side there is one bolt at the top left corner of the caliper which must be removed,not loosend it is the pad pin bolt,if your pulling the wheel anyway why not just take the caliper off with the pads in it?if you removed the two bolts[ 13mm}the caliper should just lift off!
Old Sep 11, 2010 | 07:36 AM
drillsergeantus
6th Gear
yeah your right cmonster I should just take the caliper off but I wanted to do it this way for the experiance when I dont have to take the wheel off. They came out ok but I also realized when I did it that it is easier just to take both pads out at once instead of doing the inboard/outboard the way it states in the manual. Thanks for the help you guys and you will probably see alot more posts from me for more help as I tackle the wheel next week.
RadRodriguez
Apr 18, 2018 03:48 PM
chasenfins
Sep 8, 2016 11:59 AM
Ohio HD Guy
Jul 21, 2014 11:00 PM
eberg
Mar 4, 2013 10:05 PM
mteed23
Mar 16, 2012 05:49 PM
