Forward-brake plus Mid-brake?
Old Sep 19, 2010 | 09:33 AM
SURFOR Chop's Avatar
SURFOR Chop
Originally Posted by parts eeter
No need for a linkage rod,The aftermarket forwards only use a hydrauilic brake line which you would piggyback via a double length banjo bolt onto the existing mid brake reservior. Linkage rods would be a sloppy method and look clumsy as well.
I missed your point on your earlier post ... yes ... agree that would no doubt be a better solution ....
The cost of the additional master cylinder would not be trivial, although the double banjo fitting and additional brake line would probably not be that costly ....
Old Sep 19, 2010 | 03:34 PM
Pilot47's Avatar
Pilot47
Thanks Surfor Chop, parts eeter, thetroll and jim425 for your constructive advice (and yes I agree jim, in an emergency situation both brakes are necessary to stop in the shortest distance).
Old Sep 19, 2010 | 11:32 PM
fxdx-fly-by's Avatar
fxdx-fly-by
ride with spurs on.... make **** work around here!
mattVA
Apr 12, 2015 07:59 AM
mattVA
Mar 4, 2014 08:54 AM
Ketron10a
Apr 23, 2011 05:05 PM
crazytrain1
Oct 20, 2008 10:59 AM
NA7A
Mar 12, 2008 07:49 AM
