Fall-away
Old Sep 20, 2010 | 07:33 PM
bugzapper's Avatar
bugzapper
Default Fall-away
I have seen the term "fall-away" used in here before but I'm not sure what it is. What is it? How do you correct it? I know to some this may sound like a stupid question but I am not familiar with it. I ride a wide glide, are they more prone to it than other models?
Old Sep 20, 2010 | 07:42 PM
spaceblue's Avatar
spaceblue
It is a term to describe the adjustment of the head bearings in the triple trees. When you have the bike raised on a stand or jack you can adjust the point and rate at which the front forks fall from center position to the stop in either direction. The procedure for this adjustment is described in the factory shop manual.
Old Sep 20, 2010 | 07:43 PM
dsiltman's Avatar
dsiltman
It's the the distance your front wheel moves off center before it falls away on its own when jacked off the ground. It's lets you know whether your steering head is to tight or loose.
Old Sep 20, 2010 | 07:46 PM
BONES206's Avatar
BONES206
Sometimes a short video helps. (start it at 1:10)
http://www.youtube.com/watch?v=uhKxRlxK-uQ
Old Sep 20, 2010 | 08:30 PM
ghostrider69's Avatar
ghostrider69
Sorry, I couldn't resist.
Redec
Wheels/Tires
May 23, 2014 10:34 PM
skully1200
May 1, 2012 06:08 PM
crepe
May 17, 2010 07:02 AM
gilmour68
Feb 27, 2008 01:25 AM
beemer737
May 21, 2007 04:47 PM
