Disk spacer question
Old May 21, 2014 | 03:45 PM
Redec's Avatar
Redec
Default Disk spacer question
My front forks are the older 35mm tubes with the wide glide conversion trees(10'' from center to center).
I want to put a 16x3'' wheel up front. If I buy the spacer to put a 16'' on a wide glide with 39mm tubes, can I just add a 2mm spacer? Is this a viable option?
Old May 23, 2014 | 10:34 PM
Redec's Avatar
Redec
I ordered the 39mm adapter from Vulcan along with 2 .04 spacers. I will let you know if I can get it to work with my 35mm tubes. If not I am only out $35, but I really hope this will get my disk where it needs to be.
pheur
Nov 21, 2013 07:59 AM
8541hog
Dyna Parts
15
Sep 10, 2011 09:47 AM
gilmour68
Feb 27, 2008 01:25 AM
JoeBlowme
Shovelhead
Feb 26, 2008 06:21 AM
aasce
Feb 14, 2008 06:54 AM
