I found the Progressive Suspension website to be very helpful in that it shows you what your stock suspension length is and then gives you the options of new lengths based on the series of shock you choose. From what I've been reading around, it seems like most people don't recommend going more than an inch if you are using a lowering block. People seem to be ok going lower than that using a new suspension. It's all a mix of ride height and performance/steering. For example, I don't want to lower my rear too much because I can't lower my front. I already scrape boots/pegs because of my forward controls when I go deep in to some turns. If you lower your back too much without lowering your front, you screw up the "trail" and that makes your steering messed up. If you lower both front and rear too much you start dragging bike parts on the pavement in turns. And of course there is always the bottoming out the rear arm/tire depending on what bike you are riding/how your rear is set up. Then there's a whole other mess about how soft to make your suspension depedning on if you do lowering blocks or new shocks. Long and short of it, blocks are cheap and easy to install because it just adjusts your current shocks to a shallower angle. But if you don't soften your shocks or if you go too low, you're going to regret it. Replacing your shocks is more costly but you keep the same compression angle and can improve the feel of the bike depending on how much you want to spend. This is all coming from someone who didn't know much this morning but spent a lot of time reading. I hope it helps someone looking for the same answers I was
On my last bike Just lowering the rear with blocks was good to go. With my superglide I also had to slide the forks up 1" to feel right. But Im skinny and always run the shocks on the softest setting and dont ride double. One thing that i dont hear mentioned With just the rear lowered I swear just enough primary oil moved backwards to make the clutch drag on this bike
I lowered mine 1" in the front with the Race Tech kit and went with 11.5" YSS shocks in the rear. Ground clearance can be an issue and ride quality can be effected by the decrease in shock travel. For my next set of shocks I won't go less than 12". Get what you feel comfortable with for your riding style and rod conditions.
I lowered mine an inch by replacing the stock 12" shocks with Progressive 412 11" shocks. Rides a little stiff but much better now now that I dropped a lot of weight.
Are you sure the back fender dropped that far with those shocks? I read on here where guys were using 412 series 11 in. and only able to drop 3/4 in. Maybe it's because you dropped the front too?
Does your bike bottom out any? I don't want to drop the front, just the back...what kind of drop do you think I'll get. I have an '09 dyna. TIA.
I measured at the bottom lip of the fender (below the tail light) before and after, and I was surprised at the difference too. I remember it was at least 2 to 2 1/2 inches even though the difference between stock shock and Progressive was only about 1.1 inches. The angle of the shock accounted for the multiplied effect. This was before I lowered the front. Although I noticed a slight change in the low speed handling with only the rear lowered, it was not in any way an uncomfortable or dangerous feeling. The lowered front restored the trail. A very very small difference, but noticeable to me. Have not had any bottoming issues even with a passenger. The ride is a little stiffer though.
