Help starter problem
Old Sep 25, 2010 | 01:00 PM
E9er's Avatar
E9er
Stage I
Default Help starter problem
I have a 2000 super glide, when i flip the run switch it engages the starter
starter stays engaged HELP...... THANKS
Old Sep 25, 2010 | 03:04 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Ensure your battery is charged.
Ensure battery does not need to be replaced.
Check all battery and starter connections.
Check solenoid.
I just wound up changing my starter in my '97 and these were the steps I took first. Could not get it too crank over.
Old Sep 25, 2010 | 08:31 PM
stbobfisher's Avatar
stbobfisher
First pull the wire off the solenoid the small on that triggers the starter, it the starter stops engaging it will be the starter relay or the start switch on the bars, the relay is cheap and easy to test, this happened to mine a couple weeks ago and it was the start switch that was sticking replaced switches and problem was gone.
here is a link to the thread https://www.hdforums.com/forum/dyna-...oke-again.html
RavenRider03
General Topics/Tech Tips
May 24, 2016 04:45 AM
tamann
Electrical/Lighting/Alarm
May 16, 2016 07:19 PM
ss90
Jan 16, 2010 08:04 PM
Beauregard
Jun 2, 2009 08:29 PM
cvvoord
Dec 7, 2007 01:54 PM
