starter problem w/82 shovel fxe
Old May 15, 2016 | 02:48 PM
tamann's Avatar
tamann
Stage I
Default starter problem w/82 shovel fxe
I have a 82 fxe that sat 10 yrs. after new battery oil & gas I tried the electric starter. I turned on key hit the start button and the starter cranked. when I released the button the starter kept cranking. When I shut of the ignition switch the starter kept cranking until I disabled the ground at the battery. When reconnected the battery and hit button same problem, any thoughts?
Old May 16, 2016 | 07:19 PM
Vernal's Avatar
Vernal
Go to this site and pull up your bike, or one close to it and look at the electrical starter solenoid and starter shaft with housing. I bet you need to disassemble both and clean them up. Find a good service manual to show you the steps.
Good luck
Bill
http://partsfinder.onlinemicrofiche.....asp?make=hdmc
BubbaFLMC
Shovelhead
May 6, 2019 07:47 PM
Wi_Duker
Oct 30, 2014 02:42 PM
irydasteelhorse
EVO
Feb 22, 2014 10:00 PM
roadking5555
Jul 24, 2012 05:27 PM
davewear
Apr 10, 2007 04:47 PM
