Need some handlebar help
Old Sep 13, 2006 | 12:20 PM
DDC1225's Avatar
DDC1225
Default Need some handlebar help
I am looking to purchase these handlebars and I need to know what length cables I will need to replace the stock cables, or if I will need to replace them at all. If I do need to replace them, what cables should I go with. If you could please be of assistance I would greatly appreciate it.
Old Sep 13, 2006 | 07:25 PM
mud's Avatar
mud
Default RE: Need some handlebar help
ORIGINAL: DDC1225
This is the first line from the topic you link to -
"Put these on today, and didnt have to change any cables or line."
That should clear things up.
mud
Old Sep 14, 2006 | 03:01 AM
DDC1225's Avatar
DDC1225
Sorry about that, I meant to put the link to the Nash Motorcycles website for the Gimp Hangers. It has been updated. I was browsing the forums when I posted this and must have copy and pasted the wrong link.
These are the handlebars I am curious about. I need to know what a good length of cable will be for these and what cables I need to replace.
Old Sep 14, 2006 | 03:31 AM
2HI2RIDE's Avatar
2HI2RIDE
Those are tall bars! What I would do is make a cardboard cut out measuring the the size of the bars. Tape it on the bike. Take a string and run the cabling as you want it run. Then measure out the string. Add in a couple of inches, that way you can make the adjustments accordingly. Its easier to substract from the cable than is it to add.
Old Sep 14, 2006 | 05:23 AM
16over's Avatar
16over
What size Gimps are you putting on?
Old Sep 14, 2006 | 05:06 PM
DDC1225's Avatar
DDC1225
14" Gimps
Old Sep 14, 2006 | 07:20 PM
mud's Avatar
mud
ORIGINAL: DDC1225
Derek, be sure to read your service manual when removing throttle side grip.
If you get into disassembly of switch housing the brake light switch is in there.
Have a gasket on hand for the clutch release cover, you may or may not need it.
You will need the large circlip removal/install device.
Careful screwing the clutch cable into the cover.
etc etc
mud
harleyloverswife
Dec 11, 2010 07:07 PM
hani
Aug 14, 2010 08:05 AM
tmyers89
Nov 19, 2009 06:22 AM
dewnasty
Jun 4, 2008 05:08 PM
itznin
Jul 5, 2007 03:02 PM
