Cams - some musing and data
Old Sep 28, 2010 | 09:39 AM
editbrain's Avatar
editbrain
Outstanding.
Old Sep 28, 2010 | 11:31 AM
Centerline's Avatar
Centerline
Neat graphs, tables and data correlation. I'm guessing you have a tach. It is really useful, particularly in optimizing engine operation/ gear selection to an engines dyno graph.
I also was seeking the 100/100 you mentioned. Got the torque above 100 from 2500RPM to 6000RPM.
Old Sep 28, 2010 | 12:50 PM
traveler's Avatar
traveler
S&S gear driven cams conversion and S&S 510G cams at normal advance setting gets the job done.
~Joe
Old Sep 28, 2010 | 01:58 PM
Bone11B's Avatar
Bone11B
Wow.. you've just changed the way I look at cams and performance.
Old Sep 28, 2010 | 03:28 PM
Black Bart's Avatar
Black Bart
Thanks for taking the time to share all of your hard work. It is much appreciated and confirms what cams I'll be installing in my bike.
Old Sep 28, 2010 | 04:31 PM
cramil's Avatar
cramil
WOW!! You got me wanting to dig around a bit more in my TMax. And definitely will look closer at my riding habits when it comes to motor work.
Old Sep 28, 2010 | 04:44 PM
dyna rider's Avatar
dyna rider
Default Graphs
OUTSTANDING job on the graphs and the translation. I also find the fact interesting that the idle time is huge and your motor has NEVER been above 3800-3900 rpm. Is that true ?
Old Sep 28, 2010 | 06:51 PM
SURFOR Chop's Avatar
SURFOR Chop
Hahaha ... not true ... I've pegged the redline several times, but just momentarily ....
BTW - Centerline ... no tach on my bike ... just using the 'monitoring' feature of the computer plug in and downloaded the cumulative RPM data ....
I truncated the graphs since when you've got 16 hours at some of the RPM bands, a few minutes is so negligible it just looks like zero on the graph ....
It just amazed me how little cumulative time I've spent in the last 223 hours above ... say, 4,000 RPM .... for example, I've spent just under one (1) minute at 4,500 RPM ....
For those who have the T-Max, select "TMax Control Center" and then on the "Engine Rpm Log Checkup" click the "Details" button ... you've got to be connected to your bike ....
I've 'saved' the logs, but for some reason can't pull them up from the saved files ... so I did a print screen and saved them as JPEG files ....
This is what the data looks like from the T-Max program ...
I keystroked the data into an Excel spreadsheet and did some graphs ....
I was hopeful this info would be helpful for you ... appreciate the favorable comments ....
R/
'Chop
Old Sep 28, 2010 | 09:27 PM
U-234's Avatar
U-234
I thought you did a good job of explainin the first time. The highlightin should help to make the point clearer to some.
Old Sep 28, 2010 | 10:48 PM
editbrain's Avatar
editbrain
I agree. This is very valuable information for the everyday rider. I have about the exact same commute you have to work and back. Including the two different routes. You have convinced me that if I were to get cams. I would go for a cam that comes on quick, and stays in my everyday rpm ranges.
Thank you.
