FXDX or FXR as a first HD
The FXDX or the T-Sport seems to be the ticket with it's fully adjustable suspension, dual piston/dual disc brakes and better ground clearance. The blacked out engine doesn't bother me since I don't care for chrome. The Sportsters' are out since I like to do a 4 or 500 mile day or a couple of thousand mile trips occasionally. Would a stripped down older FL be a better choice?
From what I've been hearing the FXRs had better frames so would updating a later model FXR be the ticket? I'm and ex-MC mechanic so I could do most of mods myself and keep an older bike running.
Any suggestions?
Justfnride
what it came down to was why would i spend $6-7k on a 20 year old superglide (FXR) when i could spend $7-8k on a 5yr old or less superglide (FXD).
I ended up with a 2008 fxd for $8,500. while people say fxr's were the best handling, i have NO problem scraping pegs at almost any speeds. I don't see how the handling could be much better.
and i know you used to be a mechanic, but regardless surely you'd much rather not have to work on it & just ride if it doesn't need it, right? So, you can't lose with a twin cam bike.
Any suggestions?
Justfnride
NO DYNA, even FXDX will handle as well as FXR, but thats correctable.
If you find FXDX at right price, get it. If not, look for FXD. It'll have same steeper rake as DX. Convert it to dual disc with floating rotors (like I'm doing) or just make a bracket to run good 6 piston caliper. No need to tell you about individual braided lines from MC down to calipers....
Race Tech Immulators or Works Performance Cartridge set up (like I just got). Taller adjustable shocks of your choice.
Biggest difference between DYNA and FXR is motor mounts. FXR was mounted like the Buell and handled great. Dyna needs help. There are several companies like TrueTrack or Spruthe Engineering that make stabilizers for Dyna's. I just installed True Track yesterday, so I'm still in experimenting stages, but it feels good. I'm gonna do few more things as cash and time allows, then take to Jennings for a track day.
I love FXRs and someday will own another one, but it will be in addition to the Dyna.
The older FL is not an option for me. Too big and heavy AND has same handling issues.
