Progressive Suspension 412 question
Old Sep 28, 2010 | 10:21 PM
danocanada's Avatar
danocanada
Default Progressive Suspension 412 question
Looking to buy the 412's any feedback on standard vs heavy duty? i've read their recommendations but am looking for forum feedback. i'm only 175 but do ride 2 up about 40% of the time. the 2 up wt has us at about 300. i guess i'm curious as to any single riders on heavy duty's and do they beat you to death? thanks!!
Old Sep 28, 2010 | 10:41 PM
hellfrozeover's Avatar
hellfrozeover
I am/was in the same boat. I bought the 440's in standard. I weigh about 180 and will ride 2 up less than 40% so Progressive told me the standard was the way to go.
Old Sep 28, 2010 | 11:21 PM
paul s's Avatar
paul s
I'm 220 and they're kinda stiff, I didn't notice how bad they were until I rode my brothers new Softail last night, I'm going to back them off a notch and see what happens.
Old Sep 28, 2010 | 11:44 PM
Boozefighter Borracho's Avatar
I've had 12" Black Progressive 412's for over a year now. I'm 235 and i ride 2 about 20% of the time. I didn't notice any change from the stock set up really, as a matter of fact I just took my 412's off and replaced them with Burly 10.5's...now that was a change! BTW...I'll be putting my Progressive's up for sale soon for about 135.
Old Sep 29, 2010 | 12:16 AM
hommes's Avatar
hommes
What do you mean? Do you like the burly 10.5's better? What was the difference between the two shocks?
Old Sep 29, 2010 | 12:48 AM
No...I wouldn't say I like them better, obviously a much stiffer ride to keep my fatass from bottoming out (might as well went with struts!). Actually, the 412's where much better comfort wise, but I definetly like the look of the Burlys.
Old Sep 29, 2010 | 05:08 AM
maddghost's Avatar
maddghost
First off Danocan,welcome to the forums,second prog 412's will likely be an un-noticable upgrade to your suspension IMO,however being 175 lbs I would def go with standard because at least when riding 2 up you can adjust.Heavy duty you will be fk'ed whenever you ride solo. + i reccomend not getting anything lower than stock length or longer if possible as you need that shock travel distance.
Old Sep 29, 2010 | 06:36 AM
nkauf21's Avatar
nkauf21
I'm running the 11" 412's with the standard spring. I weigh 180 and have them set on the 3rd preload setting. The ride perfect. They aren't harsh and I like how it handles lowered. It will jolt you a bit if you hit a pot hole or large bump but that's to be expected with a shock that probably has 1.5"-2" of total suspension travel.
Old Sep 29, 2010 | 07:19 AM
danocanada's Avatar
danocanada
Thanks to all, nothing like the opinion of real life users, and not the hype the ad agencies come up with!
Old Sep 29, 2010 | 07:42 AM
05sprglide's Avatar
05sprglide
I run 11" 412s on my 05 super glide. I am 170 and ride 2 up a good bit. I have no issues with comfort or bottoming out.
