Dyna Detachable Saddle Bags
Old Sep 29, 2010 | 01:46 PM
tryan31's Avatar
tryan31
Stage IV
Default Dyna Detachable Saddle Bags
I have a 09 Dyna Fat Bob. I already have the detachable sissy bar and I was wondering if and how do I add detachable saddle bags. I like the clean look with no bags but like them for a road trip. Anyone have any suggestions?
Old Sep 29, 2010 | 02:02 PM
mcbroom's Avatar
mcbroom
6th Gear
You can buy quick release brackets. I don't remember the names, but there are 2 choices. I plan on doing the same for mine.
Old Sep 29, 2010 | 02:21 PM
JRK5892's Avatar
JRK5892
here are the ones i use
http://www.edgeleather.com/Table/Har...yna/index.html
Old Sep 29, 2010 | 02:48 PM
rh8234's Avatar
rh8234
Easy Brackets and Ghost Brackets are the two most common choices. I have used the easy brackets and like them. Haven't heard anything bad about the Ghost Brackets (but I have heard that they mount the bags just a little farther from the fender brace than the Easy Brackets). Not sure if this it true, but that's the info I have gotten.
Old Sep 29, 2010 | 03:07 PM
EricInNCa's Avatar
EricInNCa
I have barebacks that I plan on using for my saddlebags. Here are a couple of pictures and then a link to another discussion on them. Pretty straight forward design that according to my local dealer is better than easy brackets as they don't rattle.
https://www.hdforums.com/forum/dyna-...bag-mount.html
Attached Thumbnails Dyna Detachable Saddle Bags-bare-backs-008.jpg   Dyna Detachable Saddle Bags-bare-backs-009.jpg   Dyna Detachable Saddle Bags-bare-backs-010.jpg
Old Sep 29, 2010 | 04:00 PM
Sumpnut's Avatar
Sumpnut
All the above suggestions are for just mounting detach saddlebags or ??? The OP stated that he allready has the detachable sissy bar/kit fitted and wants to add to it a detach bag system... on the same mountings I guess..
Thats how I'm reading it ......
Old Sep 29, 2010 | 04:27 PM
dustinn3's Avatar
dustinn3
I'm getting ready to put a set on with the quick detachable side plates as well. Sure would be nice if they just mounted to the side plates so I could just pull the whole set off at once. I'm afraid one of the edge/easy/ghost bracket systems is going to put the bags out way too far with the QD already installed.
Old Sep 29, 2010 | 06:01 PM
EricInNCa's Avatar
EricInNCa
The barebacks will install along with the detachable sissybar hardware. I have the detachable stuff and this just bolts right through the hardware and then the bags quick disconnect outside of the other hardware...
PS: Using both quick release sissy bar stuff AND another detachable setup WILL put the bags out quite a ways. I had mine on for a short period of time (10 mins) and did not like the bags spaced out so far. I removed it right in the garage as soon as I installed it. When I put my bags on, I hard mount them and use them for the weekend or whatever. Then after i'm done with them I un-bolt them and back to the quick release sissy bar setup. Slight PITA but couldn't stand the look of the wide azz bag setup.
Old Sep 29, 2010 | 08:24 PM
MYKSHD's Avatar
MYKSHD
I use the barebacks. They are REAL fussy about being exactly lined up or they don't work on my FXDF with detachable sissy bar. Mike
Old Sep 30, 2010 | 06:52 AM
rh8234's Avatar
rh8234
I used the easy brackets along with detachable sissy bar/luggage rack. No problems with it.
