New Clutch Cable Snapped!!!
Old Oct 4, 2010 | 12:56 PM
wolvie1892's Avatar
wolvie1892
Default New Clutch Cable Snapped!!!
This past Sunday, I decided to replace my clutch cable with the new +2 Clutch cable (38852-09) Since I put new throttle cables on my 09 FXD as well, I wanted them to match. Well, I pulled everything off with no problems, then started to install the new cable into the side cover. Half way into the cover, the damn threading snaps off inside it. I had no idea these damn cables were so fragile. Now I have to buy another clutch cable and a new Side cover for the transmission. So a 99.00 dollar job is slowly turning into a 300.00+ job and, to top it off, everything is backordered so I can forget about going to Bikefest in South Padre Island this weekend. I know this is a long rant, but the purpose is to find out if anyone else has had this problem and is there an easy way to make sure that when threading the side cover with the cable that it doesn't break again? Any tips would be much appreciated.
Old Oct 4, 2010 | 02:07 PM
JRK5892's Avatar
JRK5892
you tightened it too much, you do not have to buy a new side cover, just pull it cut the ball off the cable and an easy out will easily remove the left over part of the cable, it was just tightened too much, just needs to be snug, the o ring keeps it from leaking
Old Oct 4, 2010 | 02:28 PM
Desertram800's Avatar
Desertram800
Did the same thing first time I replaced my clutch cable. The second one I bought had a big bright warning tag taped to that end that said, "Caution! Do NOT overtighten, snug tighten only!".
Haha! A bit too late, but a lesson well learned. I managed to get the little threaded piece out using some needle nosed pliers, it shouldn't be in there tight, just a little hard to get a grip on it.
Old Oct 4, 2010 | 04:09 PM
wolvie1892's Avatar
wolvie1892
Talking
Couldn't get the piece out of the cover, it also seems that I threaded it at an odd angle so the threads are chewed up as well. I wouldn't want to try and put on a new cable after that, hence the new cover as well. I am thinking that when they come in I will have the service guys thread it for me.
Old Oct 4, 2010 | 05:49 PM
hommes's Avatar
hommes
I hate it when **** like that happens to me. %*#@!
Old Oct 10, 2010 | 07:21 PM
wolvie1892's Avatar
wolvie1892
Update...All fixed now. New Stainless clutch cable, new wrinkle black tranny cover, but now my damn front brake switch went out. If it ain't one thing...
gliderman
Apr 19, 2014 07:17 AM
klimoman
Dec 29, 2013 09:19 AM
knights
Jan 13, 2013 02:53 AM
bauer4567
Dec 6, 2012 08:34 PM
kylant
Oct 3, 2008 05:32 PM
