throttle troubles
Old Oct 10, 2010 | 04:25 PM
JYoung189's Avatar
JYoung189
Default throttle troubles
I got the bars installed, now the throttle does not like to go back to the normal position and when giving gas it acts like it is going to die. Any ideas of why? I can also smell more gas than I normally do.
Old Oct 10, 2010 | 04:33 PM
editbrain's Avatar
editbrain
what bike model and year?
Old Oct 10, 2010 | 10:54 PM
JYoung189's Avatar
JYoung189
2003 Super Glide Sport.
Old Oct 11, 2010 | 12:57 AM
wmo777's Avatar
wmo777
Just thinkin' out loud here, throttle and return cables reversed?
Old Oct 11, 2010 | 05:31 AM
bobnehoc's Avatar
bobnehoc
The cables are either not properly adjusted or the throttle assembly is sticking in the switch housing. Either one should be a simple fix....
Old Oct 11, 2010 | 01:55 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
I have the 100th Anniversary handlebar grips on my Dyna as well as the chrome switch housing kit. Click the links and you'll find the instruction sheets for both items, showing how to remove the old and install the new grips.
I'd advise to hang a plastic bucket on the right hand side of the handlebar to catch the brass ferrule in case it falls down.
CHROME SWITCH HOUSING KIT
100TH ANNIVERSARY HANDLEBAR GRIPS
MULTI-FIT BRAIDED THROTTLE/IDLE CABLE KITS
Check the step by step instructions and the diagrams to find out if you did the re-install in the proper way.
Pay special attention to the throttle set screw (click link to see poor man's cruise control, item 72 + 66 in image). The black half moon piece (item 66) goes between your throttle sleeve and the thumb screw.
Br125
The Dyno Room
May 4, 2017 08:44 PM
samman91
Jul 24, 2011 09:23 AM
AF Chief
Mar 27, 2011 10:44 AM
katbabie37
Aug 21, 2010 11:35 PM
fjm3rd
Oct 10, 2009 09:18 AM
