Handlebars
Old Oct 10, 2010 | 07:41 PM
donsvideo's Avatar
donsvideo
6th Gear
Default Handlebars
How much is does it cost to change my 2010 Street Bob handlebars to Drag Bars
Old Oct 10, 2010 | 08:13 PM
ed gien's Avatar
ed gien
probally just the cost of bars? You do not need no cables like apes?
Old Oct 11, 2010 | 01:58 AM
HemiOrange's Avatar
HemiOrange
$45 to $60 for low cost risers and $15 to $80 for reasonably priced drag bars. The highest cost for me was buying too many different combos to get it just right. I bought two different sets of risers and two bars before I found nirvana.
Old Oct 11, 2010 | 02:08 AM
turbostang's Avatar
turbostang
Can't change risers. It's a Street Bob, they're integrated. You could just put on a set of drag bars, but you'd have a lot of extra throttle and idle cable.
Old Oct 11, 2010 | 02:37 AM
dsiltman's Avatar
dsiltman
You would have alot of extra everything.
Old Oct 11, 2010 | 05:16 AM
bobnehoc's Avatar
bobnehoc
Change the top triple tree to an aftermarket superglide. You will now be able to change your risers to any size or style. Your clutch and throttle cables will most likely be to long and they will need to be replaced with shorter ones. The cables for the switch housing will also be too long but you might be able to just push them back into the frame. If you have not yet relocated the front directionals now is the time to do it. There are a lot of options on relocating them, you can move them to the triple trees, lower frame, integrated mirrors etc. You can also upgrade them to led's or leave them stock.
Old Oct 11, 2010 | 07:19 AM
SC-Longhair's Avatar
SC-Longhair
Have you inquired with your local dealer or independent shop about a cost?
It's not hard to do but depends how inclined you are to save the money on labor.
xantasm
Aug 23, 2014 09:31 AM
BFDHD14
Nov 5, 2013 03:04 PM
shrini23
Apr 17, 2012 10:55 AM
AndyBob
Jun 26, 2011 09:41 AM
trat73
Jan 10, 2009 12:04 PM
