Rear wheel alignment question
Old Oct 12, 2010 | 07:48 PM
megawatt1's Avatar
megawatt1
Default Rear wheel alignment question
Need some advise. Have 2000 fxdwg with a 2001 fatboy rear fender installed. Clearence between fender and tire on pully side is very close. Sticker on frame says manufacture date was late 99. VIN correlates to 2000 model year. Rear rim size is 16x3. Everything I have read indicates rim should be 16x3.5. 99 models apparently had a .200" spacer installed between pully and hub. This, I believe would center wheel up better. Checked frame with stringlines and plumb bobs and everything seems ok. Any thoughts would be most helpful as getting an answer from HD is a crap shoot at best. Thanks much.
By the way, bike tracks damn near straight. Pulls a hair to left with hands off, but may be crown in road as it doesn't happen 100% of the time.
Old Oct 26, 2010 | 01:46 AM
sbyumabaker's Avatar
sbyumabaker
I believe this.... And hope someone will correct soon if wrong. Maybe since fender is from a softail that’s why you a bit a clearance issue. If bike seems to favor one side too much; double check your rear wheel alignment. I like to use masking tape on one side then measure and confirm same distance to other side.(note) bike should be upright before performing this.
Good luck… wish I had more to add
heritagenut
Wheels/Tires
Sep 30, 2012 01:21 AM
Rokkerhead
Sep 6, 2012 08:27 PM
70Weight
Ironhead
Jun 8, 2010 10:34 PM
Coxbow
Jul 7, 2009 10:10 AM
ken thompson
Apr 15, 2007 01:49 PM
