Rea wheel not centered. Normal?
Old Apr 13, 2007 | 11:57 AM
ken thompson's Avatar
ken thompson
The Schlong Man
Default Rea wheel not centered. Normal?
My rear wheel is not centered in the rear fender. It's skewed to the left side of the bike. It also off center to the left relative to the exhaust pipes as well. Probably 1/2 to3/4 inches. I'm wondering if this is normal as the wheel needs to bealigned with the drive train components? Or am I out of whack some where.
Old Apr 13, 2007 | 12:05 PM
Madav8tr's Avatar
Madav8tr
Default RE: Rea wheel not centered. Normal?
My rear wheel is off center too. I have seen others like this as well but I don't know why some are like this and others aren't. Handling isn't affected by it and there is no abnormal tire wear so I am not going to worry about it.
Old Apr 13, 2007 | 12:41 PM
ken thompson
The Schlong Man
I appreciate the 31 views to this thread so far. May I ask that if you view this please take a moment to indicated whether your rear tire is centered in the fender or not?
Thanks in advance.
Old Apr 13, 2007 | 12:49 PM
choochoo's Avatar
choochoo
The wheel it self is NOT off centered alignment wise, unless you did something.
But as far as stock from the factory.
It is normal to have the clearances you note.
Why I don't know, just the way HD does it.
But if it bothers you, you can jack bike up, remove rear wheel.
Then the bolt at front of rear fender is accessable. This mounting
hole is slotted. you can gain some adjustment there, but not enough
in my opinion to make it worthwhile. also it really only moves the front
of fender and not the rear.
To move the rear sideways will require bending the u-tubes for the trunk.
Not recommended.
Old Apr 13, 2007 | 01:00 PM
ken thompson
The Schlong Man
Thanks choochoo. It's just a little detail that I feel should be corrected but certainly not atthe cost of what you just described.
Old Apr 13, 2007 | 03:29 PM
vernh59's Avatar
vernh59
My RK is off centered. There is a long spacer on one side of the axle and a short spacer on the other. With the fender, bags and bag rails it's hard to notice it.
It comes under "standard answer no. 3.... that's the way it came from the factory."
Old Apr 13, 2007 | 06:36 PM
EC145Pilot's Avatar
EC145Pilot
Yep, off-centered here also. I think every touring model I've seen was off-centered to some degree. It's just that way.
Old Apr 13, 2007 | 09:18 PM
impact02's Avatar
impact02
my 06 is off center too. look at the front of a 07 fatboy the front wheel is off center of the forks.
[IMG]local://upfiles/21465/478EBB7A69FA4C8FB0754CC9DD32CF0B.jpg[/IMG]
Old Apr 14, 2007 | 03:10 AM
snip0721's Avatar
snip0721
my 2000 fatboy was the same also. i machined new spacers, and caliper boss. i wanted it centered to run a 150 tire. the front pulley is wider, so the belt moves over about a 1/4 ". factory manual shows it offset. why......hellifiknow
Old Apr 14, 2007 | 06:02 AM
clarkg1124's Avatar
clarkg1124
My local dealer sez the rear wheel is offset to help balance the bike longitudally,due in part to the weight and configuration of the primary.He may be full of BS,but it's the only believable explanation I have heard so far.
Mine is offset to the left,but is not noticable while riding.
Clark
