PowerComander Gray Area
Well first I go to
http://www.powercommander.com/eng_default.aspx
there are two options, Race and Street Approved
If I choose Street Approved and then plug in my bike specs
Harley Dyna 2007 it takes me to
http://www.powercommander.com/powerc...mdl=33&yr=2007
and click on the image to jump to
http://www.powercommander.com/downlo...ngs/304500.jpg
Here are the gray areas that are confusing me. Is the street approved meant only for Californina or something other than what I am understanding it?
So, the only way to NEVER have a dyno tune is to never tune your bike and leave it bone stock.
The whole TTS setup (tts and usb cable) is around $460.
If you really want a powercommander, you can get a pcV (from fuelmoto) that is retrofitted for pre 09 bikes. You may find the autotune add-on cheaper onlline...do your tune then remove the auto-tune add-on.
Could you help a computer dummy out on that one?
Thanx
Page 63 here http://www.rbracing-rsr.com/downloads/tts_tuning.pdf
It's a pdf but loads pretty quick. It starts out talking about the 'knock sensing' technology of the Ion Sensing system but goes on to explain about adding timing across the board.
It does say that it's only about 95% perfect when you're done (good enough for most of us) and that to get the other 5% you need a dyno but -- Hey, I care.
I was goofing off a few weeks ago when I ran across an article where a guy did his own tune with a TTS then took it to a sooper professional tuner. He got one (1) more horsepower and a flatter torque curve after fifty dyno runs (and several hundred bucks, I assume).
The bike owner wasn't complaining, mind you. He was happy with the tune the Pro did. He liked it and thought it was worth the money. But, to me? One HP and a flatter torque curve? I dunno. The War Department would prolly beat me senseless for that. If I told her. Which I wouldn't.
All I know is what I read. I have no experience with tuners otherwise. But I AM ****-retentive and not afraid to do a little research. Which could be a bad thing for someone like me who doesn't have a clue what he's reading.
