Primary chain stretching
Old Oct 25, 2010 | 08:57 AM
cecharles's Avatar
cecharles
Default Primary chain stretching
How do you know when your primary chain is stretched enough so that it needs replacing and will a stretched primary chain chatter?
Old Oct 25, 2010 | 09:12 AM
oldbiker771's Avatar
oldbiker771
If it is well maintained, it will start whining around 100k miles. When your tensioner is most of the way out it is time for a new chain. I replace the clutch basket and compensator at the same time. Never heard one "chatter" exactly, but if they are real loose, they will hit the inside of the primary and that may be what you hear.
Old Oct 25, 2010 | 09:40 AM
cecharles's Avatar
cecharles
Thanks very much for the reply. I'm trying to figure out a metallic chatter coming from the primary case area. I replaced the friction discs on the clutch yesterday and checked the chain tension and compensater nut. Everything looks fine to me but it still makes the noise on the left side. I only hear it mostly when cruising and holding steady. Don't hear it during acceleration. I know sounds often travel on a bike and the origin might not be in the primary but that's what it sounds like.
Old Oct 25, 2010 | 12:51 PM
parts eeter's Avatar
parts eeter
My primary noise was the stock compensator,cured by the Screamin Eagle unit which has a much improved and tighter springpack.
Old Oct 25, 2010 | 01:25 PM
8541hog's Avatar
8541hog
What year bike and how many miles do you have on her?
Old Oct 26, 2010 | 10:13 AM
cecharles's Avatar
cecharles
It's an '01 FXD Superglide with 43,500 miles and now I'm wondering if the tensioner pad is worn or if the grooves are there from new.
Old Oct 27, 2010 | 10:55 AM
oldbiker771
It wears those grooves in there in the first 15000 or so, then the wear tapers off. It is normal.
Mark Williams
21
Aug 31, 2018 11:42 PM
Bearcat1
11
Nov 1, 2013 08:43 AM
faber
Mar 7, 2010 01:13 AM
robster
Aug 5, 2008 09:34 AM
vernfindley
Oct 18, 2007 06:54 PM
