Maybe exposing my ignorance but is this a stock plug or optional accessory, not entirely sure what plug your referring to?
If Stock try and send me a pic of the plug in question and i will lift my seat and measure for you.
Yes...it's a stock plug in the harness under the seat. If you lifted your seat and pulled it out it would be the only 4 pin rubber caped deutsch plug under there. DT04-4P is stamped on the plug. I'll take a pic and post it up when I get home. I know which plug receptacle to get just not sure what size sockets to get so it will plug up.
The size of the pins are sized by the ga. wire that they are used with. At work we use some for 18 ga. and smaller, 16-14 ga. and 12 ga up to 4 and 6 ga.
These will be detailed in your factory parts list (a great read for those restless nights!) and any parts you need can be got for a few cents at your local dealer. What are you planning to do?
Yeah I know... They are either 14 or 16 from the looks of it but I don't have anything to check them with or the wire. The place I'm looking to get all the stuff from size theirs 14 and 16-18-20. So I'm stuck with which ones to get.
Don't have a parts list. Even if I have the part number for the pin I don't think the description would give the size. I'm gonna plug a LED plate bracket into it so I don't have to cut/tap any wires.
I rigged up a hot wire for my GPS connector and plugged into the deutsch plug under the seat of my 09 Low Rider. I got the plug from Auto Zone and you can find them on their web page. I don't have the paperwork but the metal piece that the plugs were on is stamped 16-18. I think it was just a 4 pin Deutsch plug.
edit: Just checked the Auto Zone site and I can't find the 4 pin connector but you might check your local Auto Zone store as they can have one next day.
