Some New Changes to my '97 Wide Glide
Old Nov 8, 2010 | 03:36 PM
GREENOHAWK69's Avatar
GREENOHAWK69
Default Some New Changes to my '97 Wide Glide
Finally got my Harley back from the shop. Made a few changes to it:
1 - New paint
2 - Fuel gauge, welded closed, removed speedo and welded middle of tank smooth; tab welded in for satellite radio
3 - Dakota Digital speedo/tach combo
4 - Ignition moved to OEM horn location
5 - Horn moved to under seat
6 - Softail fender and back rest
7 - Fender horns cut and re-welded to fit 180 rear tire
8 - HD Tri-bar LED tailight
9 - Motor Diamond Cut
10 - Front Fender is aftermarket (purchased from J&P - do not know manufacturer)
11 - Ohlins shocks; chromed
12 - S&S Super G A/C
13 - Big PSI Carb: http://www.psicarbs.com/home.php
14 - All ***** Starter, 1.6kW
15 - Naked Girl "Gremlin Bell"
Still have to do: install LED lights
Future: new seat, motor work, Doherty Machine A/C - open, HID headlight, heated grips
Attached Thumbnails Some New Changes to my '97 Wide Glide-dscn0738edit.jpg   Some New Changes to my '97 Wide Glide-dscn0739edit.jpg   Some New Changes to my '97 Wide Glide-dscn0740edit.jpg   Some New Changes to my '97 Wide Glide-dscn0741edit.jpg   Some New Changes to my '97 Wide Glide-dscn0743edit.jpg
Old Nov 8, 2010 | 03:39 PM
GREENOHAWK69
More pictures...
Attached Thumbnails Some New Changes to my '97 Wide Glide-dscn0742edit.jpg   Some New Changes to my '97 Wide Glide-dscn0744edit.jpg   Some New Changes to my '97 Wide Glide-dscn0745edit.jpg   Some New Changes to my '97 Wide Glide-dscn0746edit.jpg   Some New Changes to my '97 Wide Glide-dscn0747edit.jpg
Old Nov 8, 2010 | 03:42 PM
Robbie13's Avatar
Robbie13
LOSER
That is one sick paint job. Looks awesome!
Old Nov 8, 2010 | 07:16 PM
goblin127's Avatar
goblin127
Look's good.
Old Nov 9, 2010 | 12:14 AM
Tech23's Avatar
Tech23
Great job. Did you do the work? Any details on what was involved with the 180 series rear tire? I saw the fender struts were cut and re-welded, how about the swingarm, pulleys,etc. Any more detail on what was needed to make the wider softail rear fender fit.
Tech23
Old Nov 9, 2010 | 06:51 AM
dpriest's Avatar
dpriest
wow, bike looks awesome, congrats on the "new" ride
Old Nov 9, 2010 | 11:59 AM
GREENOHAWK69
Tech23
I did not do the work - not that skilled.
* Swingarm = stock
* Pulley = new, used when I was running a 150 and 1 1/8" belt
* Softail fender = Stock, just lined it up for the holes on the struts and seat
* Spacers used to align everything up
I had them add some metal to the fender closer to the front of the swingarm to lessen the amount of debris getting thrown up in that area.
Old Nov 9, 2010 | 12:31 PM
Tech23's Avatar
Tech23
* Swingarm = stock
Thanks for the information. I was hoping Harley would have built what you now have when they changed the styling back in 2006. A 180 series tire is as wide as you need to go before you start getting the negative handling characteristics of rear steer from a wider tire. I was disappointed with the styling of the 2006-2008. I have liked the looks of the bobtail fender since the Schwinn Stingray. If you are a bobtail fender fan the 2006 - 2008 rear fender was a real let down. The new Wide Glide styling just makes the bike look like a hundred other smaller brand production bikes...at least the back half of the bike, the main difference is in the rake and front fork length of the others.
Have any close up pics of the tire/fender clearance and tire/swingarm clearance at the closest points? Did they cut an opening in the Softail fender to accept the Dyna close out panel (plastic cover) for access to the wiring harness, or does the rear fender now need to be removed to gain access to the harness?
Tech23
Old Nov 9, 2010 | 01:06 PM
PopsHD's Avatar
PopsHD
Newbie to the forum. Why can't I view images when they are posted like those above? I get an error message saying I can't view the page.
I get this message:
DynaWideGlide04FXDWGI, you do not have permission to access this page. This could be due to one of several reasons:
  1. Your user account may not have sufficient privileges to access this page. Are you trying to edit someone else's post, access administrative features or some other privileged system?
  2. If you are trying to post, the administrator may have disabled your account, or it may be awaiting activation.
Old Nov 9, 2010 | 02:00 PM
crazy ray's Avatar
crazy ray
i've been on this site for two years, I posted my name six months ago and I can't look at the pictures either. What am I missing, besides my brain?
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
