Re: Oil Cooler
Old Nov 9, 2010 | 06:06 PM
kentfrmca's Avatar
kentfrmca
Stage IV
Default Re: Oil Cooler
I'm a "new to me" 06 Dyna owner. This seems an extrememly active forum with lots of nook and crannies.
I'm seeking opinions on the pros/cons of installing an oil-cooler. Pointing me to a relevant thread would be helpful. Or just provide your experience, would be appreaciated.
Been riding non-stop since 1969 but haven't had a Harley since 1976. Thanks for any input in advance.
KenT frm. CA
Old Nov 9, 2010 | 06:30 PM
JRK5892's Avatar
JRK5892
all possitives no negitives... i have one on mine... love it!
Old Nov 9, 2010 | 06:45 PM
Morris9982's Avatar
Morris9982
Except for the expense and getting your hands dirty, I agree that there are only positives in putting on a cooler.
I put one on mine and would do it again. Make sure you get one with a thermostat and ensure you have all the tools you'll need. Mine needed a 7/16" (as best as I can recall) Allen style wrench to get off the oil filter adapter and to install the oil cooler adapter that goes on behind the filter.
Old Nov 9, 2010 | 06:53 PM
pcbunn's Avatar
pcbunn
"Ditto"
Old Nov 9, 2010 | 08:08 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Have them on both of mine. Peace of mind. If you get one that doesn't have a built-in thermostat, just cover it when temps are anticipated to be below 50*
Old Nov 9, 2010 | 08:54 PM
U-234's Avatar
U-234
From what I have read and been told a cooler is only required for big bores. But cooler overall oil temps can't be bad. A thermostat would be handy.
Old Nov 9, 2010 | 09:38 PM
WS6 Formula's Avatar
WS6 Formula
KenT frm. CA
https://www.hdforums.com/forum/dyna-...il-cooler.html
Old Nov 10, 2010 | 12:05 AM
goblin127's Avatar
goblin127
Twin cams run hot,so if you live and ride where it gets in the high temps its a good idea.
Old Nov 10, 2010 | 10:35 AM
JRK5892's Avatar
JRK5892
I used a lockheart cooler off an older HD, then Chad had a jack plate to run off the stock oil filter.. worked out great, and i got to mount it higher for more air flow... total cost was $50 bucks!
Old Nov 10, 2010 | 02:13 PM
Fixintu's Avatar
Fixintu
The points made in this article made a lot of sense to me.
http://www.americansteel.net/techtips/tip4.asp
Is anyone here running an oil cooler on their Dyna WITH thermostatically controlled cooling fans for the oil cooler? If you have the cooler and no fans did you do any testing with an oil temp gauge to see how much of a measurable cooling effect was achieved with the oil cooler added and the bike standing still?
Luckily I have all winter to make a decision on installing one. Riding in Texas in the summer can be a real roaster oven, especially when stuck in stop and go traffic.
