Front floating brake rotor "clunking tolerances"?
Is it normal for the front floating rotor to have a bit of "radial play" from the "isolating rivets" and hub? With the bike suspended on my HF lift I noticed that the rotor slightly "clunks" when I apply the front brake and put "rotational pressure" back and forth by hand on the wheel. I could see where the rotor was gripped tight by the pads/caliper, and the "isolating rivets" and hub had a bit of "radial play" making the "clunking".
I have always noticed it for a short while when I first take the bike out for a ride "cold", but then don't notice it after everything is "warm". I suspect the rotor gets warmed up from friction against the pads and expands a bit taking up any slack in the assembly, hence the "loose tolerances". The front brake works great (knock on wood) there is no sign of excessive wear on the rotor and its not warped, etc. but then again I'm not a brake rotor expert. Is this within normal tolerances for a floating rotor? The service manual only addresses rotor thickness and lateral runout, but doesn't mention this situation as far as I can tell.
PS:
This could defnately be mistaken by some for the dreaded "front end clunk", but its not... I upgraded to the new heavy-duty washer and inspected/adjusted the column assembly, and its tuned nicely.
Thanks for any input!
That is the nature of a "FLOATING" rotor, the disc is not tightly fixed, ie.
FLOATING! They will have some amount of "play" in the disc. That is also why a floating rotor os said to have an advancage over a "fixed" disc.
The "play" allows the disc to be evenly centered in the caliper when the brakes are applied! And the seperation of the "disc" from the mounting plate help to disapate heat and evenly cool and heat the braking disc.
It's normal.
I recently fitted a new rear floating rotor to my Glide and that is slightly loose. I also have floating rotors on the front and they haul all 1200 pounds of wife, luggage and I to a stop very well! Ride on and enjoy.
The "buttons/rivets" aren't hitting anything (like the pads), everything works like it should, its just that I could actually see the movement (and "clunk") between the two components when moving everything by hand. I'm just glad I don't have to shell out for a new rotor... or anything else for that matter!
Thanks again for the input everyone!
PS:
PS:
