Licks 12" fatty Z bars installed
Old Nov 29, 2010 | 12:20 PM
DYJ's Avatar
DYJ
Default Licks 12" fatty Z bars installed
I finally got some time of my own in my shop and got my new bars, cables, grips and mirror installed over the weekend. The bars and mirror are from Lick's Cycles the Grips are Roland Sands and the cables were all from NW Harley Davidson. I got a chance, between the down pours, to ride it Saturday. What a world of difference from my old Street Slammers. I like em a lot and am sure I'll get used to the ride.
Old Nov 29, 2010 | 12:34 PM
jpace024's Avatar
jpace024
Looks good man, got a pic of the front view you can post? Also what size riser are you using.
Old Nov 29, 2010 | 12:36 PM
Dyna_in_the_works's Avatar
Dyna_in_the_works
Bars look sick man, good job. What are you usin' for rear blinkers, i cant see em from anywhere...
Old Nov 29, 2010 | 12:52 PM
blueangel73's Avatar
blueangel73
None in the front either, my guess is he uses his left arm to signal for a turn!!!!
Bars look bad ***, do they offer them any taller?
Old Nov 29, 2010 | 01:06 PM
Live2rideUtah's Avatar
Live2rideUtah
bars look great bike looks great! I like it man!
Old Nov 29, 2010 | 01:23 PM
DYJ's Avatar
DYJ
No pictures from the front yet. I forgot to mention the risors, they're also from Lick's and they're 1 inch.
The rear signals are Alloy Art and they're on the end of the fender struts but you don't see em untill they're on... they're trick. I'm not running any front right now. I'm thinkin I'll do Joker Machine from signals, but my money tree needs to bloom again
Old Nov 29, 2010 | 01:54 PM
DYJ's Avatar
DYJ
Wich reminds me... Now my security light (the lil red key) is staying on all the time I have not hooked up a load equalizer yet so my LED rear signals are blinkin very fast also. Is that secureity light cause there is no front signals? Any ideas? I'm hopping a loda equalizer will turn the security light off?
Old Nov 29, 2010 | 02:33 PM
HOGRIDA_06's Avatar
HOGRIDA_06
The load equalizer should turn off the key light. Once you have it installed clear all the error codes and you should be all set.
Old Nov 29, 2010 | 03:19 PM
Live2rideUtah
yeah just throw the equalizer on there and it will go away, has to do with the security. With my alloy arts for some reason they were just plug and play? bought an equalizer and everything but they worked fine so I said screw it and it has been fine for a couple of years now!
Old Nov 29, 2010 | 03:50 PM
coachstorms's Avatar
coachstorms
I dig em'
But then again I may be biased...
