Help Please!!!
Old Dec 1, 2010 | 08:20 PM
TommyGunz414's Avatar
TommyGunz414
Default Help Please!!!
I am in the process of moving my mids on my 08 streetbob to forwards I got the break side on fine and am stuck on removing the clutch and inner primary to replace the clutch rods on the other side of the inner primary if any one has pics or a good detailed explanation on how to do this would be a hell of a lot of help
THanks
Old Dec 1, 2010 | 08:48 PM
TommyGunz414
looking at pictures it seems like u just remove the nut that u use to make adjustments to the clutch and it all slides off?
Old Dec 1, 2010 | 10:41 PM
ackman1968's Avatar
ackman1968
If you're going to crack the primary open you need a shop manual and some special tools. You can finish the job with out removing it, just take the short shift rod out and attach the new one to the rear arm. You can push the shift shaft that goes through the primary towards the engine and out of the way. If you look at this picture you can see that the shaft is flush with the outer primary. The arm flopped towards the back and never interfered with the operation.
Old Dec 1, 2010 | 11:59 PM
dsiltman's Avatar
dsiltman
If you look at the clutch adjuster screw there is a big snap ring that holds the adjuster screw plate in. Take the snap ring off and remove the plate and screw. The clutch hub nut is behind that and it is 13/16 reverse thread. Take that nut off and the compensator bolt out, you will need a primary locking tool. First take the chain tensioner out. Slide the clutch, compensator, and primary chain off as one piece they won't come off any other way. Hope that helps a little, sorry no pics.
Old Dec 2, 2010 | 12:03 AM
KBFXDLI's Avatar
KBFXDLI
Big Kahuna HDF Member
Do yourself a huge favor and spend the $60 on a shop manual if you are pulling the primary cover off. The cover has a tightening & torque sequence so you don't warp the cover.
Old Dec 2, 2010 | 12:10 AM
bigmikaele's Avatar
bigmikaele
another option is to cut the shifting rod that goes through the primary. Cut it behind the primary with a hacksaw blade. The rear end will fall through to the floor and the front part will pull through the primary. Then just put the cap that comes with the kit in the opening.
Old Dec 2, 2010 | 08:27 AM
TommyGunz414
Thanks alot ima do this saturday when I go back to my buddies heated garage to finish working if that fails ill go buy the manual lol
wmflhtcui
Sep 9, 2012 06:30 AM
1996Softail
Jan 6, 2008 09:48 AM
missouri traveler
Jun 24, 2007 01:08 PM
stbobber
Mar 30, 2007 10:11 PM
Skydiver
Feb 24, 2007 06:37 PM
