wide glide front end question..
Old Dec 1, 2010 | 11:36 PM
toastman's Avatar
toastman
Default wide glide front end question..
if i were to pick up a set of fatbob trees...what else would be needed to complete the conversion on my front end?
i'm thinking spacers for the fender and wheel...anything else?
thanks.
Old Dec 2, 2010 | 12:59 AM
Tat2u's Avatar
Tat2u
+ axle
by the way, you titled this post "Wide Glide" front but then asked about Fat Bob trees, you know they are not the same right?
Old Dec 2, 2010 | 01:06 AM
toastman's Avatar
toastman
meant "wide glide" more as a general term...meaning making my front end wider.
i like the fatbob trees because i don't want any added rake.
just read thru your thread(s) and wish i had your machining skills man.
Old Dec 2, 2010 | 01:11 AM
Tat2u's Avatar
Tat2u
yeah, I didn't want the extra rake either
Old Dec 2, 2010 | 04:31 AM
CrustyAngel's Avatar
CrustyAngel
does you bike have 49mm tubes as thats what the fat bob trees need ! if so !
all you will probly need is a wideglide hub get it laced to your rim, axle and spacers
plus fender
but dont go by what i say, im always wrong ask my wife
Old Dec 2, 2010 | 03:07 PM
Tat2u's Avatar
Tat2u
all that is needed is the trees, axle, wheel/axle spacers, spacer for bake rotor and spacers for fender.
Old Dec 2, 2010 | 03:08 PM
toastman's Avatar
toastman
Originally Posted by Tat2u
all that is needed is the trees, axle, wheel/axle spacers and spacers for fender.
are there readily available spacer kits?
i don't have the ability to machine my own parts like you.
Old Dec 2, 2010 | 04:27 PM
Tat2u's Avatar
Tat2u
sorry, no idea, i'm sure there would be in the US, but here in Oz prob not, I never actually looked around for them.
Old Dec 2, 2010 | 05:18 PM
JoeBobber's Avatar
JoeBobber
one other thing to consider is front brake spacing. when i did mine i had to originally space the rotor and the caliper in order for it to line up, but then I ended up switching to lower legs from a wide glide so i wouldn't need to space the brake. If you can not find a place to make the spacers, you could use a wide glide hub or wheel. Not a hard conversion, but just takes the right parts for it to work easily. i love the look of my fat bob trees with the 21" wide glide wheel.
Old Dec 2, 2010 | 06:11 PM
Blargh's Avatar
Blargh
are you trying for the full FB front end on your street bob? I just hit on this on the ride home tonight as something that'd be cool to do...was thinking of pricing out parts and what'd take to do this - will be interested to see what you come up with if you go through with it
