Is it suppose to glow red.
Old Dec 10, 2010 | 02:07 PM
gphil12873's Avatar
gphil12873
Default Is it suppose to glow red.
I have a 2010 Dyna Wide glide and the only thing was I have Rush slip on's. I dont like them by the way. Any way I havent run it in a month or so. I crank it up and let it idle for about 5 minutes. The #2 pipe was glowing red. First time I have noticed this. I know its cooler and probablly running a little more lean but dam. Is it suppose to do that.
Old Dec 10, 2010 | 02:12 PM
Wheelup's Avatar
Wheelup
NO.. it's lean like a ****
Old Dec 10, 2010 | 02:19 PM
xxxflhrci's Avatar
xxxflhrci
Glowing red head pipes are a common complaint on late model bikes. I have a buddy with a stock 2006 Street Glide. His rear head pipe often turns cherry red.
Old Dec 10, 2010 | 02:28 PM
gphil12873's Avatar
gphil12873
I want to change the exhaust, change out the air cleaner and put a tuner on it for sure. This is my first FI bike and it is different. I need to get this fixed. I didnt like that worth a dam. Thanks Fellas
Old Dec 10, 2010 | 03:21 PM
JRK5892's Avatar
JRK5892
no if the bike is glwing it is way way way too hot!
Old Dec 10, 2010 | 03:32 PM
maddghost's Avatar
maddghost
Mine used to do that when stuck in traffic or if I let it idle more than four or five minutes. I haven't had that happen since changing to bub7 exhaust.
Also when I mentioned that to my dealer he looked incredulous!
Old Dec 10, 2010 | 03:33 PM
mimo's Avatar
mimo
like this?
Old Dec 10, 2010 | 03:53 PM
T-Dub's Avatar
T-Dub
my 2010 fatbob has never glowed, glown, glowered, uh......It never turns red.
Old Dec 10, 2010 | 03:59 PM
vtwin47's Avatar
vtwin47
Before I got my 2011 FatBob, I test road a 2010 FatBob and a 2011 WideGlide in the same week. The WideGlide was unrideable due to the heat coming off the pipes which was not evident with the FatBob. The salesman said I experienced a hotter ride from the WideGlide because the seat is lower on the WideGlide. If you say so, you are the expert aren't you? Is there any consistant quality control with regard to tuning when these bikes come out of the factory, I mean it's the same engine and the same pipes? I had a carbed RoadStar that I ran Seafoam through at WOT to clean the top end and the stock pipes turned rainbow colors-talk about lean.
Old Dec 10, 2010 | 04:20 PM
07bobber's Avatar
07bobber
Id take it to the dealer to see what they say about maybe you can talk em into giving you a sert....
