PC3 installation
Old Sep 26, 2006 | 12:01 PM
Bruinx9's Avatar
Bruinx9
Default PC3 installation
This is a second request for ideas and methods....anyone who has installed a PC3 in their 06 Dyna could you help with some methods to the madness? I have the PC3 under the ecm and the bracket stuffed under the seat due to a water problem I had. I figuered I'd stuff it in a sandwhich bag and then route it up under the seat. Not sure if the "nipples" that hold the seat in place will ruin the connectors or not. What way did you all stuff yours in there? and has anyone else had a major problem with aqua in your connections? Going to myrtle beach for biketober and don't want to be stranded. Thanx a lot.
Old Sep 26, 2006 | 12:24 PM
CHEESE's Avatar
CHEESE
Default RE: PC3 installation
I attached the PC under the ECM, and crammed the connector in front of it. I live in the desert, so no water problems here...
Old Sep 26, 2006 | 12:26 PM
TOMMAY's Avatar
TOMMAY
You can put the whole thing under your seat if you want. There's a lot more room than you think. If you release all the the wiring harnesses and spread them out you've got plenty of room next to the battery to put the pciii in sideways and then fit the wiring harnesses back in around it or to the rear of the battery.
That's the corner of the pciii sticking up next to the brass bolt hole. I've ridden in rain so hard you can't see ten feet in front of you and have had no problems.
Good Luck
Tom
[IMG]local://upfiles/8936/C2A44C9EE46A400E91CBADE05809D1D2.jpg[/IMG]
Old Sep 27, 2006 | 02:53 AM
kimo's Avatar
kimo
I located my pc3 the same as TOMMAY. Ill post pics when i can make time.
77custom
Aug 16, 2017 08:24 PM
jose409
Apr 30, 2008 06:44 AM
hddave2
Feb 18, 2008 08:36 PM
flyingbobber13
Feb 17, 2008 01:56 PM
Garemlin
Detailing
Sep 8, 2006 08:36 PM
