I've got the Memphis Shades Batwing on my 2009 FXDC
Could you post some pics of the mod you had to have them do for ya..
I have already mounted HD Quick detach on my Memphis Wind shield, Wondering what else had to be done..
Get the Memphis Shades wind deflectors for the sides of the fairing and play with the recurve windshield like you said... I bet that'll help a lot.
Looks fantastic man -- one thing about these Memphis Shades batwings that look so good on Dynas is that they're not as large as the HD touring fairings. Most other after market fairing companies make fairings for Dynas that try to be as big as the touring bike fairings and it ends up looking awkward IMO -- but yours looks just right..... especially with that headlight. Nice job.
BTW: I'm surprised that your forks don't hit those lower deflector brackets when they compress...
The forks will clear, but the FORK BRACE won't if you don't add a bit of a cut-out on the
inner bottom edge of the Plexiglas. Almost everything I've done to this bike has required
small modifications to supposedly bolt-on hardware because I'm using more things in
combination than the manufacturers ever allowed for.
For instance, the front locating arm of the True Track will foul the inner flange of the
factory engine guard unless one corner of the guard's mounting is cut away and a new
bracket made. On older Dynas that have the flange on the bottom of the frame tube,
this wouldn't be a problem, but not on the newer ones that don't have that flange.
The JAGG 10-row vertical oil cooler (meant for an FL) will work fine on a Dyna.. IF you
don't have forward controls. If you do, it needs to have an extended bracket made to move
it a bit further out so that it clears the shift linkage.
Nothing all that difficult, but so many things require a bit of extra work for use on a
late model Dyna..
all sorts of fitments, but they had no idea who had used what successfully on what and I
figured I'd rather just have some made than screw around and waste dinero on trying to
force something to work.
I'm pretty sure I'm going to wind up getting a Clearview so I'll be really interested in hearing
what you think once yours is installed.
