Moisture buildup in spedometer
Old Dec 25, 2010 | 09:23 AM
Fatbob usmc EOD's Avatar
Fatbob usmc EOD
Default Moisture buildup in spedometer
I recently got condensation on the inside of my speedo on my fatbob. The best solution I could come up with was to duct tape a large desecant pack I got at lowes to the inside of the instrument panel. After a few days it managed to draw the moisture out leaving behind a couple of water spots on the inside face of the speedo. I was just wondering if anyone had better ideas. I garage keep my bike but will ride in any weather since I commute to work so not riding in the rain isn't an option
Old Dec 25, 2010 | 10:44 AM
Bluetoys's Avatar
Bluetoys
It is normal. They all do it, no need to do anything about it, the moisture goes away on it's own.
Old Dec 25, 2010 | 12:42 PM
Fatbob usmc EOD
Yeah I waited a couple of weeks for it to go away and finally had to take matters into my own hands. Once I taped the desecant in it was gone in a day or so.
Old Dec 25, 2010 | 08:15 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
Congrats on a way of removing the moisture. This is very typical of these intruments.A few years back I managed to get a tiny spider in my speedometer, it's remains are slowly wasting away.
Old Dec 26, 2010 | 07:47 AM
Stevea's Avatar
Stevea
The glass covering the speedometer on my '07 FXDL is hazy. Is there any way to remove the glass so I can clean it?
Old Dec 26, 2010 | 08:02 AM
redrubicon2004's Avatar
redrubicon2004
Usually a little time in the sun will clear up the moisture
Old Dec 27, 2010 | 08:16 AM
Stevea's Avatar
Stevea
I am sure it's not moisture. It appears to be more of a dirty film. I was hoping that there is a way to remove the glass to clean it and then reinstall it
Old Dec 27, 2010 | 08:19 AM
dFREDb's Avatar
dFREDb
Welcome to the world of Harley ownership
Old Dec 27, 2010 | 08:54 AM
Great Gazoo's Avatar
Great Gazoo
There was a post some time ago which included instructions for taking the speedo apart to clean the glass and resealing with caulking...
Old Dec 27, 2010 | 10:00 AM
R_W_B's Avatar
R_W_B
Smile
Originally Posted by Fatbob usmc EOD
..... ..... Once I taped the desecant in it was gone in a day or so.
(Also in RE: to Stevea ..... any way to remove the glass so I can clean it?)
That's an excellent idea with the moisture wicker. I just had my instrument panel off and noticed rust forming on the tank plate. I sanded down most of the rust and rubbed a silicone liquid on it before I remounted the console. (no moisture in the speedo though, so rust must have been from a previous moisture event). Next time I take it off I may just paint it.
I cannot remember for sure but I seem to remember some little screws that looked like they mounted the speedo to it's plastic base. If so you could probably get into it to clean it (or remove spiders).
The fact that a spider can get inside the speedo shows that the moisture can wick up from the bottom on the tank plate. I could see on mine that there are small open areas around the small clip in warning lite panel. So I removed it and squeezed some clear silicone around it's permeter and then seated it back on (wipe off excess immediately while fluid with some paper towels) and let it dry. That pretty much waterproofed it from leakage, although in a hard rain some is going to blow in the front of the console where the cables come in.
