RSD Vintage Short Stack.
Old Dec 26, 2010 | 08:52 PM
SPECIAL ED's Avatar
SPECIAL ED
Something else to take into consideration is the width of the bars those look to be a bit narrower than your stock bars.You might just make it.
Old Dec 26, 2010 | 09:30 PM
misfitJason's Avatar
misfitJason
Yes minimum risers would be good. If the bars are five inches to seven inches it might work but I can't be sure I have never owned a wideglide but have worked on them quite a bunch. The twincams have some leeway in the stock wiring that is feed Into the frame. So pull that out once installed and check for binding at full steer. If it binds than buy and adapter kit or solder extensions and wrap and loom
Old Dec 26, 2010 | 09:37 PM
DR. V-TWIN's Avatar
DR. V-TWIN
Former Sponsor
I think you will be okay with stock cables, but it is difficult to say for sure. Quite often cables can be rerouted and such if necessary.
Drew
Old Dec 26, 2010 | 09:39 PM
Vinsil's Avatar
Vinsil
Killer bars BTW!!!!!!! Gonna look sweet on the WG!
Old Feb 8, 2012 | 07:13 PM
retxpres's Avatar
retxpres
Ok, so did you have to change the cables?
What size risers did you use?
Could you post more photos....
Old Feb 8, 2012 | 07:24 PM
KungPowMinchow's Avatar
KungPowMinchow
i was able to use the stock throttle cables and ill have to measure the clutch cable cause i think that i went a lil longer with it. 1.5 risers on my short stacks
Old Feb 8, 2012 | 08:37 PM
WideGlideRide011's Avatar
WideGlideRide011
i know 1in risers and the bars work...i just put them on my glide...if you re route the cables alittle bit i think you should be just fine
Old Feb 9, 2012 | 09:39 AM
secondlook's Avatar
secondlook
I really like those bars post some pics
Old Feb 9, 2012 | 09:52 AM
RICHIEMACK's Avatar
RICHIEMACK
Originally Posted by secondlook
i really like those bars post some pics
,,,set for sale cheap in muti fit section chrome
Old Feb 9, 2012 | 09:56 AM
RICHIEMACK's Avatar
RICHIEMACK
I have a set ..you can get away with changing just thr risers to 1 or 1 and a half,you might have to change your thorttle and idle.. Cheap...i have a set of chrome ones same rise 7in for sale in the classifies ..rsd bars...anyone interested pm me $130 shipped they go for $300.nice bars
