Wire connectors.
Old Jan 1, 2011 | 01:59 PM
redmonster13's Avatar
redmonster13
Default Wire connectors.
I am trying to change my bars and cant seem to get the wiring connectors for the bars apart. Is the molex tool absolutely necessary or can I improvise something.
Old Jan 1, 2011 | 02:04 PM
soft 02's Avatar
soft 02
Soooo much easier with the tool thingie.
Old Jan 1, 2011 | 02:10 PM
Phrogman's Avatar
Phrogman
I haven't checked the newer bikes, but they should be running deutsch connectors, not molex. If you look in the male portion, there should be an orange plastic piece, pull that with a small flat head screwdriver. Once that's out, you can depress the tang which captures the pins in the connector. For the female plug, the orange piece is right at the top. Pull that off and same-same. There is a rubber water sealing gasket on the back end of both connectors that you can pull out to make the wire removal easier, but the wires actually pass through the gasket.
Old Jan 1, 2011 | 02:12 PM
nevil's Avatar
nevil
check out the video in this post: https://www.hdforums.com/forum/dyna-...sassembly.html
redmonster13
it is definately molex, if they were the other kind I would be done now
Old Jan 1, 2011 | 02:19 PM
redmonster13
video is exactly what I needed, thanks.
Old Jan 1, 2011 | 02:29 PM
soft 02's Avatar
soft 02
If you have a small piece of tubing or a ink pen tube it makes it easier to release the locks. My Molex un locking tool is just a steel tube with a handle.
Old Jan 1, 2011 | 04:01 PM
FXD2003Rider's Avatar
FXD2003Rider
Administrator Emeritus
Check out these posts by mud:
Wiring
...........mud
............................amp connectors
https://www.hdforums.com/forum/4277699-post1092.html *
............................deutsch connectors
https://www.hdforums.com/forum/4277701-post1093.html *
........................................deutsch source
............ .............. ................... http://www.deutschconnector.com/
............................molex connectors
https://www.hdforums.com/forum/4277695-post1091.html *
Old Jan 1, 2011 | 04:26 PM
redmonster13
well I got it apart, started wiring the RSD bars, now I have decided that I will pay someone else to do this ****. My time is worth to much to me to spend that long wiring. I dont like doing it at work but at least when I am messing with electrical on a car I am getting paid.
The bars look amazing but they are an absolute nightmare to get the wires run and doing it with the sleeving isnt an option. Looks like the stealership will get a couple more bucks from me.
DanHappy
Mar 11, 2015 08:41 PM
TylerBoehm
Jun 11, 2014 02:14 AM
1931jamesw
Aug 21, 2011 04:01 PM
rubiconMike
Aug 29, 2008 07:44 PM
Way2Fast
Jun 12, 2007 08:49 AM
