Fork oil level ? - Street Bob
Old Jan 14, 2011 | 07:32 AM
parts eeter's Avatar
parts eeter
Originally Posted by DCLXVI
Well I changed out my fork oil today when I had my front tire off for replacement. I changed out the spacers and went with the same length you did, 5/8" over. I'm 220# with gear but I frequently carry between 30-60# of gear with me so I'm guessing it should be close. I also went ahead and cut another set 1/2" over in case I don't end up with enough sag. I didn't use 20 wt oil though, I cheaped out and used ATF. I'll be taking it for a test drive tomorrow to see the results. Thanks for posting the helpful info. I have had plans to do this for a while but the write up helped me get all the stuff I needed before disassembly. BTW the crappy bolts on the cap are 8x1.25mm and 35mm long. I was able to find a set of them at Lowe's for $.80 each. Mine where not stripped but there is definitely not enough metal on them and the quality of the factory fasteners is pretty crappy.
No problem, I also upgraded my triple clamp fasteners to chrome units from HD that I matched up from the bolt bin. I never heard of someone using ATF in forks before...I am sure it will work but the lack of viscosity selections would make tuning damping action impossible. If you like how the forks perform with it then that is great, if not change it out to fork oil. I suspect you would be happy with 15wt for your application.
Old Jan 14, 2011 | 09:54 AM
bobnehoc's Avatar
bobnehoc
When ever you change the fork oil, follow the directions in the service manual. They give specific measurements. You should not go by how many ounces as it is only an approximate measurement. When I PC my front end on my 08 SB, tripple trees and legs I followed the instructions for determining the correct fork oil level. It's height is measured rather than done by volume. It does make a difference......
Old Jan 14, 2011 | 10:04 AM
83efi's Avatar
83efi
Ok. Sorry for the miss info. My manual also says that the forks need 3.74 or 28.6 oz in the forks. Progressive says to put the fluid level down to 5.5 inches from the top of the fork tube since the kit drops the front end 2 inches. I never saw this in the install instructions and am hopeing this solves my front end issue. Will keep you posted.
Old Jan 14, 2011 | 11:24 AM
bobnehoc's Avatar
bobnehoc
That sounds about right.....You need to measure the level not by volume but by height down from the top of the tube.....
Old Jan 14, 2011 | 11:56 AM
DCLXVI's Avatar
DCLXVI
Not only has it been done plenty of times, some manufacturers specify it as the recommended fluid.
I did finally get out for a test drive today and I like it. It is still very smooth over irregularities on the road but there is noticeably less dive when braking and even shifting. The factory set up definitely needed improvement. Now it feels very balanced front to rear. I have Progressive 440's in the rear with the sag properly set up.
flyguy9631
Mar 28, 2017 05:43 PM
MHRider
Mar 3, 2013 06:43 AM
Robcat
Apr 28, 2010 08:24 PM
fastjoe
EVO
Oct 15, 2009 09:19 AM
jjwin98
Mar 22, 2009 04:53 PM
