Motor build Should I ??
With my buddies deal I will be getting all the stuff listed plus the labor we will do ourself minus the tune I would get that done. So bascially he would be hooking me up with labor I havent really done motor builds but he has so here is what I would be getting for $2300.
So basically is whether I want to go with off the shelf parts with the S&S kit or with his pretty blown out setup he has 150 miles on his build if that when we dynoed it he saw I think so dont quote me 125HP and about the same TQ if not more..
Hillside cycles stage 4 heads
10.7:1 compression
CCP was at 199 front and rear
1.800 intake ports
2.0 inch intake valves
1.63 inch exhaust valves
40 degree high tulip
kibble white black diamond valves
manual decomp releases
Hillside cycles honed cylinders
Wiseco forged dome top pistons
Bob Woods TW8-6 cams
Barnett clutch pack
Screamin Eagle big twin compensator
You have a great platform and accessories to build on, but you may want to go with a larger throttle body and injectors and also a larger air cleaner like a Wimmer that will fit the Arlen Ness (Stage 1?) set-up you currently have. This will help balance the air in/air out a bit and give you better flow for those larger valves, etc.
Also consider installing an oil cooler for the added heat that you will be generating. Too bad UltraCool doesn't have one of their fan cooled models available yet for Dynas. I gave up waiting for them, ordered a Jagg's, and plan to install a fan kit before summer hits.
That's the route I'm taking, similar to yours, but without the compensator. I'm using a Revolution Performance 107" kit, 625 cams, head work, etc. and will also have about 10.7:1 compression.
Are you still thinking of ditching your front brakes and doing a built engine?
Yeah I was gonna send my throttle body out to HPI I was wondering do I have a two piece or a one peice? Also yeah I am def doing a wimmer for more flow I hadnt thought about injectors or an oil cooler but I will now thnks.. So you think should I?? What do you think of the PC 5 should I get rid of it and go with the TTS or a HD Tuner??
Yeah I am gonna run a front brake maybe even leave the dual disks....lol
Cylinder boring $80.00
Cams $250.00
Gaskets Cheap
Labor FREE! I will do it myself.
HP I expect from these parts along with standard mods, air cleaner,tuner I already have,pipes already on my bike. Right around 100HP and 100ft lbs of Tq.
I am cheap and this will get the job done for me. To obtain around 100 HP is fairly cost effective and simple, but anything over that than the cost goes up big time for headwork,valves,crank truing and welding.
Note* If you still wanna ditch your dual brakes I want your lowers, rotors, and calipers!!! Just remember R titled bikes arent worth as much!
You want the Thundermax Tuner.
My other project is the chopper I just built be doing a nice motor build on that soon too brotha this aint my first BBQ so I aint scared..
She took me 6 months...
