Q: rear pilion seat install
Old Oct 2, 2006 | 11:57 PM
07NYBOB's Avatar
07NYBOB
Default Q: rear pilion seat install
The instructions are confusing as hell.
Has anyone installed the rear pillion seat successfully with the grab strap?
Or should the strap be skipped. It says that the strap has to be mounted with the screw going from under the fender. Is this possible with the wheel on?
I'm a bit confused. Can anyone provide me with some simple instructions on this, please?
2007 Street Bob
Old Oct 3, 2006 | 12:25 AM
DougsDyna's Avatar
DougsDyna
Default RE: Q: rear pilion seat install
I strapped mine to the seat bolts. Usually use my Corbin solo seat, so it makes removal/install of the 2up easy.
Seemed impossible, but probably can do from belt drive side of bike.
DD
Old Oct 3, 2006 | 12:39 AM
misfit's Avatar
misfit
I left the strap off
Old Oct 3, 2006 | 12:53 AM
KeithB's Avatar
KeithB
Big Kahuna HDF Member
but bike up on the jack will drop tire some, unhook the shocks will drop down even more
Old Oct 4, 2006 | 10:33 AM
irlm1's Avatar
irlm1
i havent put a screw in there, or tried to mount a seat so sorry if this info is of no value, but hey worth a try..... i put a rack on there with a plug underneath and found a piece of fishing line handy to get it in.
.....try putting some line thru the hole from the top, push thru until you can grab it, tie on the screw and pull it back up. dunno, havent seen the screw so maybe its too long for that.
unfortunately that was the only use my line got in the last 2 years. maybe next year.
Old Oct 4, 2006 | 10:52 AM
ameristo's Avatar
ameristo
I have a sissy bar I use for 2-up so I just left the strap off.
[IMG]local://upfiles/6102/46FA0434CDFD4531A9423303E1FC2773.gif[/IMG]
Old Oct 4, 2006 | 11:55 AM
Stanger's Avatar
Stanger
I did put the strap on, but I will tell you know that it is not easy. I put mine into the bolt hole that is closest to the front of the bike, under the seat that is not being used, I believe. If you are going to do this, you will need to jack the bike up some how. Good luck and if you need any more help, let me know.
Old Oct 4, 2006 | 01:08 PM
powerman's Avatar
powerman
I left the strap off on mine but i also run a sissy bar.
Old Oct 4, 2006 | 02:23 PM
rogue_rob's Avatar
rogue_rob
I used some thin wire and ran it from the top down to the bottom through the afore mentioned hole.
Tied the bolt to the wire and pulled it back through the hole.
Easy Peasy Japoneesy
Old Oct 4, 2006 | 08:56 PM
Rhode Warrior's Avatar
Rhode Warrior
I just wrapped it around the pillion and bolted it to the bolt that holds the pillion to the seat. I also have a sissy bar.
