shifter
Old Jan 20, 2011 | 03:00 PM
2007nightrain's Avatar
2007nightrain
6th Gear
Default shifter
i have a 1987 fxrc that was my uncles before he past away. i need to lift the shifter at least 4 inches before it will shift. anyone know what might be the problem. p.s. just joined and lov'n the site. you all have some great look'n scoots.
Old Jan 20, 2011 | 03:35 PM
07bobber's Avatar
07bobber
All i can think of is adjust the lever?
Old Jan 20, 2011 | 03:42 PM
SURFOR Chop's Avatar
SURFOR Chop
Take a look at the linkage ... there may be a problem with some of the parts ... bad heim joint, teeth busted off a splined shaft or shift lever ... something like that ...
Could be a combination of factors ....
Post a couple of photos of the shift lever (up close), the linkage and the shifter lever (transmission) ....
Welcome aboard ....
R/
'Chop
Old Jan 20, 2011 | 03:43 PM
dsiltman's Avatar
dsiltman
Check to see if the shifter is slipping on the shaft.
Old Jan 20, 2011 | 03:44 PM
misfitJason's Avatar
misfitJason
slack in the linkage or it is very poorly adjusted
Old Jan 20, 2011 | 05:48 PM
2007nightrain
6th Gear
The whole linkage moves with the shift and shifter is not slipping so must be internal? ? Thanks for the feedback and the kind welcome.
cwsharp
Aug 22, 2022 11:54 PM
dh_meyer
2014-2024 Touring Models
Aug 11, 2017 09:32 AM
INJEKTER
Sep 12, 2015 06:33 PM
c50plus
Dec 16, 2011 12:36 PM
DaSham58
Dec 19, 2008 01:34 PM
