Fat Bob Head-Pipe Catalyst
I've got a '09 Fat Bob, but also have a set of '08 pipes, and want to add Rush Slip-Ons without the added catalyst constriction.
Hey, old-skewl! Funny you should ask - I just posted a couple of days ago on a header swap I did this past weekend on my FB (see 'FXDF header swap' on 01/24). To answer your question, my '010 came with a cat stuck inside the collector, and the used '09 pipe (according to the seller) I installed did not - it was completely flow-thru. On your '09 if you pull off the muffs and shine a light into the collector you should see nothing but open pipe, no honeycomb cat; just clamp on your Rushes and you're good to go!
That's right...my '09 doesn't have it and I've got the Rush slip-ons for now...
