Extending Front End for Lowrider
Old Jan 26, 2011 | 02:28 PM
doer's Avatar
doer
Default Extending Front End for Lowrider
I have an 2003 fxdl, just put on 1/2 inch longer heavy duty progressives on rear to gain some cornering clearance(works and rides GREAT)...Now the front end pitches down ever so slightly and I'd like to bring the front end up. I figure I can (1) get a taller front tire...(2) get two inch over fork tubes...(3) get a wide glide front end... The tire would be cheapest and might do the trick. How big a job are the longer fork tubes? The wide glide front end is about 600 bucks- would that just bolt on to a Lowrider? Any inputs?? THANKYOU
Old Jan 26, 2011 | 06:04 PM
fixxr's Avatar
fixxr
Wideglide front will go on,But make sure you use the wide glide tire&wheel.2" over tubes are about $185.and take about 3hr to change.
Old Jan 27, 2011 | 08:40 AM
Mascman's Avatar
Mascman
Can you push the tubes down any in your trees?
Might be all that you need to get rid of the pitched feeling.
Old Jan 27, 2011 | 08:59 AM
SURFOR Chop's Avatar
SURFOR Chop
The other thing you could do is take up some of the sag--and stiffen--the front fork springs by taking the caps off of the fork tubes and inserting a 1-1/2" to 2" length of PVC tube and reinstall the caps ... you'll probably need a helping hand and a means of compressing the fork springs to get the caps back on ... I'll see if I can find a photo (I recall forum moderator, Mud has some good pics of the operation) ....
R/
'Chop
p.s. Post by Mud with a photo of him putting his fork leg back together is at https://www.hdforums.com/forum/6799297-post1537.html ... this was copied from his series of posts at 1167, 1168 and 1169 in the "* HOW TO * under fifty bux *" sticky thread, demonstrating how to install 'intiminators' (fork oil valves) ... even if you're not installing intiminators, it is a good 'how-to' on removing and servicing the Dyna front end ....
widerider96
May 29, 2016 08:52 AM
sluginxlt
Oct 8, 2014 07:54 AM
odd_child4life@hotmail.com
Apr 30, 2012 05:33 PM
FrenchXD
Feb 1, 2010 01:29 PM
Two_Into1
Jan 15, 2007 06:12 PM
