I have a 2005 FXDCI and want to install a new derby cover....
when I remove the stock HD cover will oil come out???
and will I need a new gasket when I put the new cover on????
Nope, you should be ok as far as oil. I always inspect gaskets when I am changing things. I do not think there is ever anything wrong with replacing gaskets/O-rings regulary. Better no leaks than...well....leaks (due to worn gaskets). Its not like they are expensive anyway.
The short peice of 2X4 works fine,.. But to be sure just change the Derby when you change fluids..
And Like Geronimo said 'Gaskets are cheap',, besides some Derbys require special gaskets.. Mine did..
